Question about Samsung LN37B650 37 in. LCD HDTV
On and off switch just clicks away set doesnt come on
Stand by light on at red just flashes
  • 85 Answers
Caps dead clicking is relay attempting power up
Posted on Nov 30, 2012
3 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: TV will not switch on at the remote or on the set,
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, red light blinging codes, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 04, 2009
Russmann
  • 203 Answers
SOURCE: The stand by red light keeps switching on and off resulting in no
Most of the time this problem is caused by the power supply in the set. Capacitors on the circuit board wear out. Usually the ones rated at 10 or 16 volts. You can see a physical bulge of the defective components in most cases. The way to repair this is to either replace the bad parts or the circuit board itself. If you take this to a repair shop the cost should be less than half the cost of a replacement tv or 125-295 u.s. dollars. If you have test equipment and solder/desoldering equipment you can repair it for 20 dollars or less. The only way to be sure that this is the problem is to have someone disassemble the set and check it. But this has been only a very educated guess. Good luck, Russmann.
Posted on May 13, 2010
What to do with red blinking ON/OFF button on philips mci500h 12
Internal Power supply and could be a shorted diode or a relay could be causing the flashing red light. Usually the red light indicates the System is in stand-by mode or not in stand-by. If when you used to turn it off there was a red light though not flashing, then that means it is in stand-by so in that mode your remote works on some older sets work and others it doesn't matter because the remote will always work. Unplug it for a half hour and try it and see if the light stops flashing. Might help to give more clues towards the fix.
May 15, 2014 | Televison & Video
MY TV FLASHES 7 TIMES ON THE POWER/STAND BUTTOM
ensure the lamp cover door is firmly pressing the kill switch and the red light will stop and u can turn on the telly
Jul 05, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
My device a red blinking light with a dark screen.
The red blinking light can mean a couple of things. First, It could mean that you have a message. If that is not the case, you caould have on the 'LED Coverage Indicator'. The LED Coverage Indicator tells you by having the top light flash eather Green or Red depending on coverage. If you are in a place that has good coverage it wil flash Green but if you have little or no coverage the LED will flash Red. To check if you have this setting enabled, first go to "OPTIONS" on the phone in the full menu. Once there, go to "SCREEN AND KEYBOARD". Click on 'SCREEN AND KEYBOARD" and scroll down will you see the option that says "LED COVERAGE INDICATOR". Click on that and switch it to OFF if it is not already there. Then click the back bottton and click SAVE. That should work. If it doesnt, I would call your phone carrier and ask them.
Feb 19, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Sony Vega KDF-E5OA10,picture will not come on, tv goes off.
There is a real good chance that the lamp fan is not turning. If you look with a flashlight in the vent on the left side looking at the rear of the set and have someone turn on the unit, see if it spins. if it doesnt, the protect circuit in the tv will not let the set turn on. Replacing the fan will cure the proplem if it is not turning.
Hope this helps,
Skyassoc
Jun 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Red light flashing/won't turn on
you are right about replacing the thermal compound between the cpu/gpu and heat sync. the gpu and cpu may need to be refolowed also. another tip is dont over tighten the screws. Tip: keep your ps3 flat do not keep it standing. when it is standing and heats up the thermal compound can start to move away from the heat sync. Keeping it flat will help extend the life PS3 at least from the overheating issue.
May 14, 2009 | Sony Playstation 3 (PS3) Console
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Samsung LN37B650 37 in. LCD HDTV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
