Question about Car Audio & Video
Remote for MTX thunder 8101D - Car Audio & Video
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Try online or ebay Or from a car audio store that sells (MTX) Amps,
Posted on Nov 27, 2012
  • 86 Answers
SOURCE: Schematic for MTX Blue Thunder Pro 752 amplifier
hello ..try this ...www.eserviceinfo.com...takes a bit of working out how to get them .when you do .you have to download bitzipper (these are a rar file)...then adobe 8 ..bitzipper can convert to a pdf flie so you can read them...hope you have some luck
Posted on Feb 12, 2008
  • 149 Answers
SOURCE: MTX Thunder problem
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
Posted on Jun 04, 2009
  • 84 Answers
SOURCE: mtx thunder 304 4ch red amp light comes on but no audio
if the lights on and there is no sound it's either a cd player issue or your rca issue or the inputs for rca's on the amp are no good. or you have your subs wired at a wrong load to your amp and it is in a constant protection to avoid burning up.
Posted on Jun 14, 2009
SOURCE: MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Posted on Jan 23, 2010
kcarmax
  • 30 Answers
SOURCE: i have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Posted on Mar 01, 2010
How do I Bridge MTX Thunder 404 400 watts into one channel
The mtx thunder is a 4 channel amp. 4 channels can't be bridged to 1 speaker. You can only use one side of that amp to bridge your speaker. Unfortunately your now only using half your amp.
Nov 25, 2016 | MTX Car Audio & Video
Ayuda con el MTX THUNDER 895
Ojala que no pagastes mucho por el. SI tienes un tecknico cerquitas te lo puede reparad barato. Si lo tienes que mandar a MTX no conveine.
Feb 19, 2014 | MTX Thunder 5-Channel Amplifier 895 Car...
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
Connection
My guess is a short in your 12 volt remote turn on wire or you have it wired incorrectly behind the dash. If you're sure you have a good ground and a solid battery wire the only other issue can be your remote wire. Your remote wire is what kicks the amp on and illuminates the power light.
May 31, 2010 | MTX Thunder 251D Car Audio Amplifier
I have a mtx thunder 421d. I've had it about 5 years,about a week ago it started going out from time to time. I checked my hot wire and fuses,they are ok.Now the amp stop working, and dont light up. Will...
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did!
800 225 5689 - MTX Customer Service & Amplifier Service Center
Good luck !
Jan 31, 2010 | MTX Thunder 421D Car Audio Amplifier
My friend sold me his subs today and one sub doesn't work. they're mtx thunder 8000 will mtx fix the sub for me?
They probally would, but i just found that sub for 51.00 im sure it would cost that and more to have.it fixed
Nov 09, 2009 | MTX Thunder 8000 T8104 Car Subwoofer
I have a mtx thunder 1501d..i have the power cord connected from the battery, to a power cap and then to the amp...i have the ground connected to the metal frame of the car, to a power cap and then to the...
Hello tonytone54, The ground should go directly to the vehicle frame, never through a cap, fuse, or anything else. Also, if you are connecting positive through a cap, make sure that you charge the cap before connecting it. Hope this helps.
Jun 03, 2009 | MTX Thunder 1501D Car Audio Amplifier
Wiring details
thunder 81000D not bridgeable,i have two daul voice coils kicker cvr how would i wire them up?
Mar 30, 2009 | MTX Thunder 81000D Car Audio Amplifier
I need installation instructions for a MTX thunder 280
BATT = 12v positve constant
GND = 12v negative or ground
REM. = 12v positive switched or remote wire.
The remote wire is most commonly found on aftermarket CD players. It's typically in the main wire harness. The most common color of this wire is blue with a white stripe.
Jan 20, 2009 | MTX Thunder 2-Channel Amplifier 282 Car...
I need help hooking this up
"is the got two wires in the ground and remote turn on wie"
Can you be more specific about the wiring...where the two wires are connected to and where they come from, and I'll try to help you.
Mar 29, 2008 | MTX Thunder 895 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
