Question about Refrigerators
I have an odor in my magic chef rb193p refrigerator freezer how can I correct this?
    New Friend:
    Problem Solver:
  • 16 Answers
Cleaning and baking soda
Posted on Nov 28, 2012
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
  • 44 Answers
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Posted on Apr 18, 2009
  • 7 Answers
SOURCE: freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Posted on Apr 19, 2009
  • 16 Answers
SOURCE: bottom of refrigerator not getting cold enough
have you cleaned out the coils underneath the fridge? it's very simple. pull the fridge out, look underneath(try pulling off the bottom grill from the front for more access), and start cleaning. to much dust and lint will hinder the coils from cooling. A vacuum with the brush attachment or little broom works good.
Posted on Jul 27, 2009
  • 396 Answers
SOURCE: My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Posted on Oct 20, 2009
Magic Chef RB15FA0AA Refrigerator I have this refrigerator and it still works fine. I would like to know it's total cu ft capacity. Also what the refrigerator and freezer each cu ft capacity is.
After some work online...I found this advertisement buried among a bunch of other ads:
Magic Chef RB15-1A: Top-freezer style with 14.6 cubic ft. capacity and optional ice maker -- $439.
So, as I suspected the "15" in the model number is the cubic feet (total I would say). The 14.5 is probably actual, with the unit "rated" as a 15 CF.
Naturally, to find the cu. ft of the freezer, measure in inches then multiply the width X height X depth and divide that resulting rather large number by 1728 to get your cubic feet of the freezer.
You could also do the same with the refrigerated section, and add the results together and they should be near 14.5 total.
Aug 03, 2015 | Magic Chef Refrigerators
My magic chef rb193p fridge wont stop running. I replaced the fan motor 4 months ago. The top of the fridge compartment is freezing. Is the defrost timer bad?
I had the same problem. When the evaporator heater stops working, frost will build up until there is no air flow to the refrigerator. This will cause the refrigerator to keep running. Remove everything from the freezer and remove the pan at the bottom and see if there is a frost buildup. .... Bruce
Jun 18, 2011 | Magic Chef CTB1922 Top Freezer...
I have a Magic Chef refrigator and it freezes up
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
Jul 07, 2010 | Magic Chef CTF1826AR Top Freezer...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Aug 27, 2008 | Magic Chef Refrigerators
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
