Question about Blenders
I have an old Vita Spa MT10, took off the pump a couple years ago and don't remember the connections. Is there a wiring diagram for this?
Looking for the wirign diagram for my spa
Where can I buy a clutch for a vita mix 5000
Shop for buy a clutch for a vitamix... on Google
Amazon.com: Vitamix Drive Socket Kit: Electric Countertop ...
www.amazon.com/Vitamix-891.../B0028Y4CVE
Amazon.com, Inc.
Rating: 4.7 - ‎249 reviews
Shop Vitamix at the Amazon Small Appliance Parts & Accessories store. ... blender on the fritz, PLEASE do yourself a favor and check the old drive socket before buying a whole new blender. .... This fitted perfectly into my vitamix super 5000.
Vita-Mix Parts: OEM Replacement Parts ' Parts Town
Dec 03, 2015 | Vitamix Vita Mix 891 - 1-Drive Socket Kit...
Where can I find a motor
Vitamix says they will fix units up to 20 years old or so????
check here:
Contact Us Customer Service Vitamix
Don't know about 30-40 years old????
good Luck
Feb 23, 2014 | Vitamix Vita-mix 3600 / 4000 Handle For...
Diagram of 06 jeep grand cherokke blend doors
Asking about a Jeep Grand Cherokee in the kitchen blender department will probably not get you the information you need.
Jul 25, 2013 | Vitamix Vita-Mix 18007 Door Cover for...
My 55 year old waring blender model #1037 has stopped
What I would do is try to see if the manufactor is around yet, like maybe looking on the internet for them or if you have the paper work yet for it look for a phone number on it and see what they say,or maybe a repair man in your area knows what to do about it.
Jan 09, 2013 | Blenders
I have a Vita Mix 3600. I was making a fruit smoothie (banana, blueberry, raspberry), milk, small scoop of protein powder . Speed was on 1. I depressed the lever to reverse. I don't remember if I had...
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
Jun 09, 2011 | Vitamix Vita-Mix 1364 3-Speed Blender
I have this model and a vita prep 3. Both turn off when tasked with heavy blending. Is there anyway to increase their blending torque capacity? They used to be much better. They are not old machines.
The motors even if they not old blenders if they have work with too much load for along time then they have been overheated and thus they will trip overheat safety more sensitive. So now actualy you have less blending torque as you have describe. So now their is much posibilty if you continue to work it the same way you will finally burn the motor rotor so the damage will be grait.
So now not only you can not get more torque but you should try to avoid very heavy use in order to have them work for a longer time.
When you use with a lot of ice cubes try to cover them with a lot of liquids and always use the pulse mode to start ant the continues rotation.
Good luck
Aug 14, 2010 | Vitamix 1003 Vita-Prep Variable Speed...
Blenders Logo
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
