Canon PowerShot A4000 IS Silver 16MP Digital Camera w/ 8x Optical Logo
Anonymous Posted on Nov 26, 2012
Camera repair.blogspot.com PowershotA4000 IS
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 09, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
81
Points
Have a very nice post
more information for your site.
Tv Repair Birmingham
Where I can get it repaired?
As far as I know it is less expensive to replace than to repair, but if you really like the camera, try Canon repair service or live chat weekdays: http://www.usa.canon.com/cusa/consumer?pageKeyCode=onlineRepairLanding#
You can thank me by joining me at http://outsideshooter.blogspot.com
My lens wont close
Take a look at these useful articles. Truth be told if the camera is under a year old take it back to where you purchased it and see if they can't get it sent out to be fixed. If you have no warranty on it you will likely want to try one of the methods in the articles below or buy a new camera. As sending it out to get any of these repairs done generally costs more than the camera is worth.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
My camera canon power shot sd 1300 is dont work it say error reset automaticalli
You could be having a power problem, or lens issue. The following blogs discuss things you can try to get the camera working:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
and:
If nothing helps, contact a local camera shop to get an estimate for repair, or contact Canon support:
http://www.usa.canon.com/cusa/consumer/standard_display/support
Good luck, and hope this helps.
Mar 01, 2011 • Cameras
When turning the power on my stylus 710 the lens comes out like normal but on the screen it shuts off to a black screen and doesnt allow me to take any pictures, I can't get the lens to go back in or able...
This type of problem can be caused by either a lens issue, or power problem. The following web blogs delineates things you can try to get the camera working again. They say about 50% of the time they can be fixed trying their suggestions:
If none of those things helps, try these steps:
If the camera still doesn't work, you can take it in to a local repair shop, but get an estimate first. Repair can be high, and justify just going ahead and buying a new one.
It wont stay on when i tur it on it only stays on for a second
Chances are it has a stuck lens issue, but it could also be a power problem. The following two web blogs detail things you can try, to fix it:
and:
If none of these step helps, you can take it into any camera shop for an estimate for repair, or contact Kodak at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=8991&pq-locale=en_US&_requestid=4949?cm_mmc=Google_MarketForce-_-Store-_-Camera%20-%20Support-_-kodak%20support
4helpful
Lens error, reset camera, how do i fix?
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
1helpful
Canon PowerShot A720 IS - "Lens error, restart camera".
Cannon Power Shot SD550 Digitalelph
Sorry, missed your previous posts. The following blog outlines some simple repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty. Hope they help:
Wish you the best of luck. But keep in mind though that you have a 50/50 chance of repair with the above techniques. If they don't work, the camera likely needs replacement of the lens assembly. Unfortunately, due to the complexity of the repair (a LOT of things in the way), the cost of such a repair usually outweighs the value of the camera.
The following two links are repair guides for fixing a cracked LCD on similar SD500/600 models. They include some photos that may help illustrate how deeply buried the lens assembly is in the sd elph cameras.
http://exploded.awcr.org/DigitalCameraDisplay
http://cannonlcdrepair.blogspot.com/
2answers
A560 canon digital camera
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
2answers
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
