Question about Oreck XL2200 Bagged Upright Vacuum
Why isn't my oreck xl sucking up dirt, instead it is blowing out air
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
CorvetteKing
  • 108 Answers
SOURCE: Oreck Celoc Hypo Allergenic Vac tearing up rug
Most parts and service are covered on those machines for a year. (the 5 year part is just the motor and some "fluff" for advertising purposes) I would call oreck and find the nearest warranty service center. You should find they will fix it at no charge as long as its not deemed "abuse".
If you call them and they will not help, repost and we'll get you fix'd up!
Best of Luck!
Posted on Jun 09, 2009
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
SOURCE: My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Posted on Nov 06, 2009
  • 36 Answers
SOURCE: Oreck vacuum blows air does not **** air. The bag
you have an obstruction in the intake pipe
Posted on Nov 20, 2009
It seems to be blowing the dirt away instead of sucking it in?
Sounds like it has blockage somewhere in it causing low suction, therefore brush 'blows' dirt away instead.
Jan 27, 2016 | Oreck Vacuums
Oreck vacuum is blowing out air and not sucking up dust. Why is it doing that???
Most likely the air passage from the motor to the bag is clogged.
Take it outside, remove the bag, and turn it on. That may blow the clog out. If not, open it from the bottom, and try to snag the clog out.
May 14, 2015 | Oreck Vacuums
What's your problem? Oreck XL Power Team Lightweight Vacuum not picking up dirt
i have just purchased a oreck xl how do i move the handle so i can hoover
the floor
Oct 27, 2012 | Vacuums
My Oreck XL upright vacuum is blowing air instead of sucking air.
I've solved the problem! I had exactly the same problem, with dust being sucked up properly and then some blown out where the bag connects. The XL machine has a hinged plastic dock for the bag, which slides in the dock and you then close the hinge, there's a slight click and the velcro keeps it shut. The problem is that the plastic dock is not behind the ridge, but is in front. So when you start up the bag connection is pushed forward. So:
Undo zipper, open dock hinge and push it back squeezing the panel on the cloth bag. One side will go behind the ridge and you need to push it firmly, opening it a bit if you can. It will go behind that ridge all the way round. You'll see now that the dock is firmly in place, and can be hinged closed as you did before. But instead of the joint being loose, the bag is now tight.
Mine now works fine... thanks to fixya for encouraging me to fix it! I was close to binning the machine. But it sucks well, and I don't go for bagless... like my dirt packaged for disposal. And if you're a farmer, try farmideas.co.uk !!!!
Nov 25, 2010 | Oreck XL Deluxe U3700 Bagged Upright...
My vacuum seems to be just pushing around things instead of sucking them up. I changed the bag and cleaned the bottom, but nothing helped.
Did you check to see if the drive belt for the beater brush was broken or frozen up? The beater brush hits the carpeting and causes the dirt, etc, to jump into the air so the suction of the unit can pull it into the vacuum. The beater brush will be fairly easy to remove. Once it is out of the machine, clean it as best you can, add some WD40 on the plastic end pieces and when you reassemble, put a new drive belt on. This should solve the problem. Paul
Oct 11, 2010 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL is very dirty inside on fan and the motor runs very loud. It is not clogged.
These units are called dirty air units because the dirt literraly runs thru the fan attached to the motor and is blown into the bag. Most newer vacuums are called clean air because the filter bag is in the path, and the dirt is sucked into the bag, never reaches the fan or motor.
I'd say if it is that dirty, may be a fire hazard, and you may have worn out the seals on the part down at base that pivots to a point that replacement is necessary.
(I'd blow out the dust and keep using if it was me, and then check again in a few weeks, before I replaced. But I like living dangerous.)
Jun 22, 2009 | Oreck XL21 Bagged Upright Vacuum
Best of Luck!
Jun 08, 2009 | Oreck XL2000 Bagged Upright Vacuum
Not sucking
You probable have a clog in the handle tube, or at the bottom, either by the brush or in the neck where the handle goes into. Unscrew that big black nut and pull the handle off of the bootom asm, then you can check it out and see where the clog is. Pull the bottom plate off to see if it is there where the dirt goes in.
Feb 17, 2008 | Vacuums
Oreck XL2200 Bagged Upright Vacuum Logo
62 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
