Question about Canon PowerShot A4000 IS Silver 16MP Digital Camera w/ 8x Optical
My camera give message lens error restart camers
Powershot A4000 IS
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Nov 26, 2012
3 Suggested Answers
  • 421 Answers
SOURCE: i have a canon powershot
Very difficult to repair at home due to having to remove most of the camera insides to get to the lens mechanism. The lens then needs to be opened in a dust free enviroment and repaired. Your best bet is a local independent repair shop.
Posted on Nov 03, 2010
Ranglo
  • 1194 Answers
SOURCE: lens error,restart camera
This error occured when lens is prevented from properly extending or retracting.when pressure is applied to the lens or the area surrounding the lens while handling the camera.
Avoid applying pressure to the lens and surrounding area:
  • Do not touch Lens while shooting.
  • Make sure the camera is off before the camera is placed back in the case.
If you cannot clear the error code by turning the camera off and then on again then your device need to be repaired.
Rating the solution is highly appriciated...Good Luck.
Posted on Feb 28, 2010
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
Aug 27, 2015 | Canon PowerShot A4000 IS Silver 16MP...
My camera keeps saying "lens error, restart"?
you keep turning it off and on untill the lens open up fully
Dec 30, 2012 | Canon Powershot A4000 16mp 3" Lcd 8x...
CANON POWERSHOT a4000 IS LENS ERROR RESTART CAMERA
Most lens error codes on a Canon A4000 are caused by a broken pinion axle pin or sheared gear teeth in the lens extender gearbox. If this is your problem you can get a new gearbox or gears at: Gearbox for A4000
To watch a YouTube video on how to repair this go to: http://www.youtube.com/watch?feature=player_detailpage&v=oMpFFtzQJwg
Aug 19, 2012 | Canon PowerShot A4000 IS Silver 16MP...
My camer says lens error,restart camera waht do I do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Apr 27, 2010 | Canon PowerShot A1100 IS Digital Camera
Lense error, restart your camera
If i told you to smack it around a bit would ytou believe me?
But that is the fix Canon use to get rid of these errors 98% of the time.
Charge or change the battery, insert it tuen camer on when it goes off smack it hard into your palm a few times and turn it back on.
Just incase there is some dirt/dust stopping the lens from extending blow a can of compressed air around it and give it another few slaps . Sometimes after about 20-30 ngoes of this the camera will jump back into service Believe me it does work nearly all the time Canon charged me $90 to do this trick
Jul 29, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
Lens error restart camera but it just switches off i keep getting a lens error restart camers error i turn it off and on but get the same error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 28, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot A4000 IS Silver 16MP Digital Camera w/ 8x Optical Logo
154 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
