Question about Sharp Actius MC24 (PCMC24) PC Notebook
Every time i trun on the laptop (sharp pc-mc24) it does not locate the hard drive
  • 564 Answers
Check in your bios and see if your hard drive is showing. If not remove the hard drive and connect it again.
Posted on Nov 26, 2012
Paeroa
  • 457 Answers
SOURCE: Need to Upgrade Hard Drive & Memory for Sharp PC-UM10M
SHARP PC-UM10 SPECIFICATIONS
CPU Ultra Low Voltage Mobile Intel® Pentium® III processor 600 MHz-M Memory 128 MB SDRAM, not expandable (model PC-UM10) 256 MB SDRAM (model PC-UM10M) Video ATI Rage Mobility M (including 4 MB video RAM) Display 12.1" XGA AGLR TFT LCD (1024 x 768) Hard Drive 20 GB Pointing Device Glide pad (touch-sensitive control pad with 2 buttons) PCMCIA 2.1 Card Slots Type II x 1, CardBus port supported Audio System Monaural microphone and monaural speaker, sound system compliant with AC 97 I/O Ports USB, LAN, modem, headphone, microphone, DC in, expansion port for port bar Modem 56Kbps (V.90) LAN 100Base-TX/10Base-T AC Adapter 100-240V, 50-60 Hz Battery Rechargeable lithium ion battery Battery Life Standard battery - approx. 3 hours. Optional extended life battery (CE-BL18) - approx. 9 hours. Battery life is based on ZD Battery Mark 4.01. Battery life may vary based on actual usage. Dimensions 11.1" x 9.1" x 0.65" (min)/0.77" (max), 282mm x 232mm x 16.6mm (min)/19.6mm (max) Weight 2.89 lbs., 1.31 Kg Operating System Microsoft® Windows® 2000 Operating Environment Temperature: 50°F to 95°F (10°C to 35°C) Humidity: 20% to 80% (non-condensation) Power Consumption Max. 40W Available Options Extended Life Battery CE-BL18 Optional longer life battery 6X CD-ROM Drive CE-CD05 External USB CD-ROM Floppy Drive CE-FD04 External USB Floppy Drive Port Bar CE-PB01 Provides additional I/O ports
Design and specifications are subject to change without prior notice. Some options may not be available in some regions.
[HOME] [NOTEBOOKS]
Posted on Oct 22, 2007
tom19511
  • 1601 Answers
SOURCE: Sharp Actius MC24 PC Notebook overheating and shutting down
If it under warranty I would take it back to them.
If not I would open it up and check for dust build up and make sure the fan is working...
Posted on Aug 01, 2008
RescueTechLA
  • 2653 Answers
SOURCE: Sharp notebook can only be repaired by Sharp, according to Sharp
What does the jack look like? Can you post a pic?
I'm pretty good with finding ones that are compatible.
Posted on Feb 26, 2009
  • 166 Answers
SOURCE: where can i find drivers for sharp pc-mc24?
use the link below to download the drivers:-
http://driverscollection.com/?V=SHARP&S=43
dont forget to vote
Posted on Nov 21, 2009
chalkperson
  • 147 Answers
SOURCE: I need a replacment DVD drive for my Sharp Actius
Use the link below and find the nearest supplier to you. Ian.
Posted on Jan 25, 2011
No sound drivers sharp actius mc24laptop
You can download the audi and device drivers from the Sharp WEB site.
Select your model notebook and the Windows drivers you require. Please click on this link to the Sharp support WEB site :-
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Feb 18, 2012 | Sharp Actius MC24 Notebook
I need a replacment DVD drive for my Sharp Actius MC24 notebook
Jan 24, 2011 | Sharp Actius MC24 Notebook
Sharp MC24 notebook will not charge the battery
The charging element on the mainboard that passes the AC/ to a resistor is out, gone, needs to be replaced and in saying that the mainboard comes with it unfortunitly.
Thanks for using fixya.com
Your Sharp Expert
Aug 31, 2009 | Sharp Actius MC24 Notebook
Feb 26, 2009 | Sharp Actius MC24 Notebook
I can't burn my pictures into a cd-r using nero smart start. how will i be able to burn my pictures?
first u please check that a cd-writer is available in your laptop, if so then start nero smart stat, select data cd, select files to burn and push the burn button.
Nov 20, 2008 | Sharp Actius MC24 Notebook
Aug 01, 2008 | Sharp Actius MC24 Notebook
Sharp actius mc24
Do you know how to flash the BIOS? This could trigger it. Are you sure that it can accept the hard drive. Does the hard drive have jumpers on it? This should be on master if it does have one. Although not common on laptop hard drives it could have one.
Mar 21, 2008 | Sharp Actius MP30 Notebook
Black-Out
Hi Jonirik,
Perhaps you can try determining if the laptop's problem is either the LCD display panel, the video card or the CCFLamp. If you can then maybe repairs can be done locally in Palau and you can source parts online.
If the unit powers up and goes through the motion of booting:
1. to determine if LCD Panel Display - connect the laptop to an external monitor. You may need to press Fn + F? key to activate and view display on the external monitor;
2. to determine if CCFLamp (and/or inverter) - power up the laptop and shine a flashlight obliquely to the screen. If you can see some semblance of display/desktop, no matter how slight/dark, then the backlight (CCFLamp) and/or the inverter is the problem; and/or
3. If there is no result on #1, then it is possible that the video card is the problem. In some instance, it could be memory, motherboard or something internal to the unit.
As to your other concern, I made inquiries but it would seem that Sharp Phils. doesn't accept laptop repairs. Nonetheless, most incoming service request are forwarded to their Service Centers.
In any case, contact information for Sharp Philippines is below:
SHARP (PHILS.) CORPORATION
Km. 23 West Service Road South Luzon
Expressway Alabang, Muntinlupa City, Philippines
Telephone Nos. (63) (02) 842-1371, 842-0525 to 29
FAX No.842-0530
Contact E-mail: sharpb2b@spc.global.sharp.co.jp
Customer Care: jlacosta@spc.global.sharp.co.jp
Service Toll free number: 1-800-1-888-4952
Feb 05, 2008 | Sharp Actius MC24 Notebook
Memory upgrade for a Sharp PC MC24
Do you have shared ram on your laptop?, i mean if the graphic card use the same ram as systems then the ram will be shared between graphic and system, however to get the good result the 512 won't be enough try 1gb to get good performance.
Nov 30, 2007 | Computers & Internet
Sharp Actius MC24 (PCMC24) PC Notebook Logo
57 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
