I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works except the volume control.
  • dlmunn Jan 12, 2009
    This did not solve my problem! I will check with comcast to see if they can solve my problem. I do not feel that I should have to pay you a fee of $ 19.?? to fix a problem for a brand new TV.
  • 14 Answers
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Posted on Jan 10, 2009
I need to hook my hts5580w up to my tv so it plays the sound from my comcast cable
You'd probably get better digital multichannel audio if you source it from the Comcast Cable Box. Treat it like any digital source audio component and skip the TV, which adds nada to the audio by being in the loop.
On the other hand your video will be best if IT goes straight to the TV from the Box and skips the Philips. Again, nothing gained and more possibly failing interconnects if it routes to the HTS.
Jun 23, 2011 | Philips HTS5580W/F7 Theater System
I am looking for all replacement fuses in for the 47" model, model # 47PFL3603D/F7
Best thing to do is contact a local tv shop, some fuses are specialized so its best to be sure you are getting the correct values. we sell them for a couple of dollars each.
Oct 30, 2010 | Philips 47PFL3603D LCD TV
I have an haier model L32R1 and comcast cable just came to install and the comcast remote will not work can you tell me what the universal code is to get the remote to work.
i have the same problem and still looking for the code :( but for the mean time i just hook up my digital box to the tv threw the video inputs. hope this helps you.
Dec 03, 2009 | Haier HL32R 32 in. LCD TV
I can't get my philips 47pfl3603d/f7 to work with a coby dvd968 home theater system the tv has one spdif coaxial out and coby also has one i pluged the cable, still can't get to hear my tv channels thru...
You need to select the source of your home theater system. Press <SOURCE> on the home theater remote to switch between DVD, TUNER, and LINE modes. Select LINE, then you should now hear audio from your TV, Please make sure that your TV is not muted, just increase the volume until you hear audio on home theater. Also increase the volume of your home theater.
Regards,
Jeep Brainy
Jul 26, 2009 | Philips 47PFL3603D LCD TV
What is this tv's setup code? Needed for Comcast cable box opera
are you sure that your comcast remote requires xxxxx 5 digits for the TV code ?
10054 ?
most remotes use 4 digit codes and in my book, the philips codes are:
0054
1454
0690
1154
try these
and if you are sure that the comcast remote uses 5 digit codes then try these
10054
11454
10690
11154
make sure you get the Red LED code entered Confirmation Blink after entering the code digits.
its either a double blink or a Long Solid blink
if you have 4 digit codes it will blink before can enter the 5th, so you will know
Ed
Jun 16, 2009 | Philips 13PT30L 13" TV
Need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Jan 03, 2009 | Philips 47PFL7403D 47 in. LCD TV
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
Digital conver. on 2/17/2009
This TV comes with a dual tuner uhf/vhf in and digital antenna in .hook to digital antenna input and change input on remote to dtv hit menu and let it scan for channels.
Nov 15, 2008 | Sanyo HT32546 TV
New digital box from comcast, codes listed not work for their remote, search mode turns no code either. TV model #CM19022S, Serial #3CDT703826H assembled July 2002...don't if it comcast box or tv....this...
Hello!
I'd be happy to get you in touch with the right team to assist you with your remote. Please email our team at We_Can_Help@cable.comcast.com.
Regards,
Melissa Mendoza
Comcast Customer Connect
National Customer Operations
Oct 09, 2008 | Televison & Video
TRU TECH TV CODES
try code 10030 (comcast remote), or codes for daewoo.
Mar 28, 2008 | TruTech PLV16190 Television
Televison & Video Logo
185 people viewed this question
Top Televison & Video Experts
Electro Med Services...
