Question about HP LaserJet 3700dn Printer
I have smear lines and roller smudges on all my copies.
How do I fix this?
  • therosenbull Jan 10, 2009
    Thank you, oh wise Guru!!
    My father-in-law is an HP printer tech, He gave me this, not going into to much detail, what was wrong. He also live 900 miles from me. When I could not get him on the phone, I went to the next best thing, FIXYA and The Guru. Thanks again
    Chef Ox
    Sergeant:
  • 290 Answers
You need a roller maint kit with new rollers, contact HP or a local printer repair shop they are usually fairly cheap.
Posted on Jan 10, 2009
  • William Douglas
    William Douglas Jan 10, 2009
    lol, np I beleive the kit usually runs around $50, some are more some are less
  • William Douglas
    you are most welcome
How do i fix vertical and smear or smudge on a printed document, exactly on the far left corner on the paper.
you must check the image drum for problems. If you dont see something check the fuser assembly the pressure roller of the teflon that cover the heating element in fuser assy.
Aug 05, 2015 | HP LASERJET PRO P1606DN PRINTER
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
Feb 13, 2013 | Canon Pixma MX410 All-In-One Printer
Hp printer prints smudge on side of paper
I Suggest You To Watch
Ink Smears Smudges or Splatters on the Printout To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On : HP Printer Support
Dec 18, 2012 | HP Pick Up Roller Rm1-0885 for Laserjet...
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
Copies have ink smudges at top of all pages. Canon Imagrunner 2000 model. It seems that the toner is showing up on each copy.
this is problem with fixing nip - pressure between fixing roller and silicon pressure roller.
To fix this you need to change the fixing roller, bushing of fixing roller and maybe silicon roller.
Call service!
Hope that helps!
Sep 02, 2011 | Canon imageRUNNER 2000 Copier
The ink is smearing on to the copy. The text keeps on reappearing on the page.
It sounds like either your drum needs to be replaced (needs to be done every 5 or 6 toner cartridges), or you have a bad fuser (depends on what you mean by smearing).
When an image reappears further down the page (not as dark or bold) it usually means that the current in the drum is not correct, or the coating on the drum is worn. Take the cartridge assembly out and separate the drum from the cartridge. DO NOT TOUCH THE DRUM ROLLER. Look at it and see if there are streaks, color differences, or toner on the drum roller. The roller should be solid purple or green with no marks, lines, toner, or smudges on it. If it does, the drum is a replaceable part and you can get one anywhere that sells toner cartridges. They are even available in remanufactured brands.
However, if there is loose toner on the paper (wipe your hand over it and it comes off), then your fuser is bad and needs to be replaced. Another problem with the fuser you can check is whether there is toner being adhered to the fuser rollers, which could cause smearing and images to reappear on the page. To check this, open the rear cover of the printer. Inside you will see two rollers: usually an orange one on top of a black one. Be careful; the fuser can heat up to almost 400 degrees, so let it cool if you were just using it. Check to see if there is any toner on these rollers; if working properly, they should be spotless. If there is toner visible on either roller, then you may need to replace the fuser.
It is a 75% chance of your drum being the cause, which would be the problem to hope for. If your fuser is bad, in all honesty it may not be worth fixing; it can cost you up to $150.
I hope this helps! Good luck!
Mar 02, 2011 | Brother HL-2170W Laser Printer
We have a Ricoh Aficio CL3500N. We are getting a
Never clean or touch the Transfer Roller (spongey rooler) unless your using a dry cloth or vaccum as last measure.
Usually the transfer roller sits on a drum/pcu specific to that color. If you can tell which color is sitting on to of the roller replace that drum/pcu.
Jul 15, 2009 | Ricoh Aficio CL3500N Laser Printer
My old Canon NP1215 Copier: -First copy is
most probably a change of the drum and cleaning blade is needed ,check also the fixing/fuser roller
Jul 11, 2009 | Canon Office Equipment & Supplies
PC-65 (Canon copier)
A smudge across the copy can be in many different areas.
Some ideas.
The drum cleaner may be the problem as you indicate.
It may be a piece of paper ripped of dragging across the surface of the paper causing the smudge.
Also the fuser roll coating may be very worn and causing that.
One thing to try that can show you if the defect is on the drum cartridge, is start to run a copy, After the paper feeds and this is timing, shut the machine off when you think the paper should be about half way through the copy cycle, then see if the copy defect is on the unfused page, If it is smeared before it reaches the fuser, it is in the cleaning section, if it is not smudged, then it is most likely the fuser rollers are needing replaced.
First look for a paper fragment in the path, step 2 is to shut the machine down in mid copy and see if the defect is there.
The fuser is the hot area of the machine in the exit area, If you can take a flash light and look in there and see if you observe wear or heavy toner buildup on a roller then obviously thats the problem.
Jan 02, 2008 | Canon C130F Black and White Copier
"Clean drum" doesn't get rid of smears.
Need to change cartridge, the residue is not being cleaned off by the Drum Blade.
Oct 29, 2007 | Samsung SCX-4720FN All-In-One Laser...
HP LaserJet 3700dn Printer Logo
126 people viewed this question
Ben Johnson
