Question about Xerox Phaser 6500DN Laser Printer - Color - Plain Paper Print - Deskt
Clock error 116-364 - Xerox Phaser 6500DN Laser Printer - Color - Plain Paper Print - Deskt
How to stop WB27K5040 from beeping F1 error code
Unfortunately, the F1 error means that either the touch pad has a short or the "clock" (electronic control unit) has failed. Sometimes the wire between the touch pad and the clock fails. To test for the exact problem, you would need to unplug the range and access the clock from the back of the range. Unplug the touch pad from the clock. Then plug in the range again. If the error does not recur, the touch pad is bad. If the F1 error and beeping repeat, the clock is bad.
GE sold the clock and touch pad as a single unit for the WB27K5040. Since this is an older model range, the replacement is not in stock. There are some places that offer to repair the clock. You'll need to remove the part (or get a service person to do it) and send it in. Your range will be unavailable for some weeks while this is attempted. Otherwise, you should replace the range when the issue becomes too frustrating.
I hope this helps.
Aug 28, 2014 | Ovens
Tip
REGULATION TIPS FOR THE 400-day and 1000-day clocks
CLOCK REGULATION TIPS FOR THE ROTATING REGULATOR
These Regulations tips are useful for regulating the rotating regulator. This is to include most 400-day and 1000-day clocks.
The following information is copied from SCHATZ (tm) OWNER'S HANDBOOK.
Time Regulation Tip:
On the top of the pendulum is a disk on which numbers are engraved 1 - 16 and two arrows marked F - S. The small indicator hand will be pointing to a number on the disk at which the clock was regulated before leaving the factory. Should you find it necessary to regulate the clock, observe the number to which the indicator hand points. The distance between each number is equivalent to 1/2 minute in 24 hours + or -.
FRROM MY PERSONAL SHOP NOTES:
If your clock loses two minutes per day [24 hours] and the indicator hand points to number 8 on the disk - move the disk in the direction of the arrow marked F until the indicator hand will point to number 1.
NOTE:
Before attempting adjustments to the regulator disk, first lock the pendulums by using the lever located on the front of the base. By so doing, you will avoid damage to the delicate suspension wire while turning the regulating disk.
Keep A Regulation Record:
Keeping a short Record of regulation and maintenance on your clock will make it much easier for you to keep it well with in its optimum time-keeping ability. We have found that using the guideline below helps.
Date: +/- in min: How much adjust in Degrees +/-: Personal Notes:
We recommend logging only the times the clock was wound, and any time the clock is regulated or reset.
Times of regulation will include any time the clock has exceeded a 3 to 5 minute error.
Use only ONE form of time references for this, a QUARTZ clock that is known for keeping good time is recommended.
Over time you may find the clock needs only slight regulation; for example, if it has run for approximately 3 weeks and the error rate is under 3 minutes adjust regulator only slightly or simply RE-set.
TEMPERATURE and SEASONAL CHANGES
Temperature fluctuation can affect the time-keeping abilities of your clock.
Never allow direct sun light to come in contact with your clock. This will over heat the clock and it will not only affect the time-keeping qualities, but also dry out the oil and cause premature servicing requirements.
SPECIAL NOTES: REGULATION TENDENCIES
It is very difficult to look at the hands of an analog clock and still determine if the clock is running correctly, therefore I recommend allowing the time error rate on the clock to remain UN-touched until the error rate has exceeded + or - 3 to 5 minutes. This is because 1 minute is very difficult to observe and calculate effectively.
One little known fact about the Rotating Regulator: After the clock is restarted it can take up to 3 or 4 hours for the pendulum to settle down into regular beat rate. Example: If the pendulum is under rotated the clock will run fast and will take some time to bring it up to speed. If over rotated it will run slow. RECOMMENDATIONS ARE: Look at the actual clock time and reset it as closely as possible to real time after the clock has run for about 3 to 4 hours but don't disturb the pendulum. ONLY RESET THE CLOCK IF the actual clock time is off by 1 or 3 minutes.
If you must reset the clock every 3 to 4 weeks, and it is FOR EXAMPLE always slow, Slightly RE-Regulate the clock to compensate for this rate of error. Simply reset the clock several times just to make sure that no mistakes are made.
How to Calculate the Adjustment:
Calculating how much to turn the regulating nut on the rotating pendulum by using the following calculations.
Link to data base located at http://antiqueclock.clockstop.com/Regulate.html
Hope this tip helps.
r/David
on Feb 17, 2010 | Watches
Error Message F2 E6
Perform the following actions to fix your error:
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'Upper Cancel key ' function and wait for 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thank you !!
May 30, 2010 | Whirlpool RBD305PR Electric Double Oven
I entered radio reset code for 2002 civic now the clock flashes and will not allow me to adjust it. How to solve this problem
Okay, I'm assuming that you were sucessful in resetting your radio code.
I'm also assuming that you have a CD player (which may not be the case).
The flashing clock also functions as an error code indicator. It should say something, indicating what the error is. You can't set the clock until the error is resolved (a disc stuck in the CD player, for example, on no disc in the CD when it's been told to play).
The procedure is as follows (which you probably know):
The audio system display usually shows the time when the ignition switch is in ACCESSORY (I) or ON (II). It shows the operation mode of the radio, cassette player, or optional CD player/changer when you operate them, then goes back to the time display after five seconds.
If an error occurs while operating the optional CD player or changer, the display will keep showing the error code and will not switch to the time display until the error is corrected. You can set the time only when the clock is displayed.
To set the hours, press the H (Preset 4) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the H button until the hour advances to the desired time.
To set the minutes, press the M (Preset 5) button while pressing the CLOCK (SCAN/RPT) button. Press and hold the M button until the minutes numbers advance to the desired time.
If you don't have a CD player, or no error is showing in the clock read-out, leave a comment so I can investigate further.
Hope this helps you.
Nov 11, 2009 | 2002 Honda Civic
F1 error message on the clock. Oven will not work. I purchased a new clock and recieved the same error. What could be the problem? Could it be the heating element?
The meaning of the various error codes varies by manufacturer and model. If you replaced the clock/control board you may have found a tech sheet taped to the panel that you removed to get at it. Usually the tech sheet will explain the error messages. If not, email me at bruce@fixyourboard.com and I will attempt to find the info for you.
Oct 14, 2009 | Kitchen Ranges
What is a f13 error code on a Frigidaire Gallery smooth top stove
Hi danair2,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Aug 14, 2009 | Kitchen Ranges
Philips AJ3040 suddenly shows error code 3040
Mine had the same problem but fixed it byh replacing the capacitors inside the alarm clock. It works like brand new now!
Apr 04, 2009 | Philips Audio Players & Recorders
Both ovens and clock are not working
F1 error usually signifies a broken touchpad or clock assembly or both. I would start with replacing the clock assembly as this is the most common cause of the F1 series error. If it does not resolve the issue you may have to replace the touch pad as well.
Good Luck,
Sai.
Feb 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Error codes
Clock error it happens when the external clock goes out of sync with the internal clock nothing to worry about it should have went away on its own after about 30 seconds
Dec 06, 2007 | KitchenAid KEBC277 Electric Double Oven
Xerox Phaser 6500DN Laser Printer - Color - Plain Paper Print - Deskt Logo
513 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
