Question about Sony Televison & Video
Connecting sony dvd player dvp sr160 to tv and sky
MikeNJ1964
  • 398 Answers
SOURCE: sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Posted on Sep 01, 2007
SOURCE: Sony DVP-NS57P all region
try thomson
Posted on Feb 04, 2008
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
Posted on Dec 21, 2008
  • 10 Answers
SOURCE: SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
  1. In the setup menu there is a setting for Custom Picture Mode.
    Could someone have turned the color down?
    You can go to the setup menu and "Reset" the player to the factory settings.
  2. How is this connected to your TV?
    Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
    If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
    If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
    Are the cables in good condition?
    No breaks, loose connectors, they weren't smashed under a piece of furniture?
    Have you tried a different set of cables?
  3. Test the DVD player on another TV.
    Does the same thing happen?
    Did you "Reset" the DVD player?
    Maybe the DVD player is bad?
  4. Find another DVD player and test it with your TV.
    Does it work OK, or is it black and white too?
    Maybe the connectors on the TV are bad?
    Is there a custom setting on the TV for that connection?
    On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
There are may possibilities, but these are some of the basic things to check.
Best wishes,
-Greg-
Posted on Sep 14, 2009
  • 909 Answers
SOURCE: How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
Posted on May 15, 2010
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
Connect iPod Classic to Sony DVP-FX970 portable DVD Player
You may refer to this tutorial, it's about how to connect iPod to TV, it should also work for DVD player.
http://www.reviewstown.com/how-to-connect-ipod-iphone-ipad-to-tv.html
Hope
it helps. Contact me if you have any other question.
Jun 03, 2013 | Televison & Video
Need code for sony dvd
These WEB sites may help make your player region free.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Oct 22, 2012 | Sony Televison & Video
Having trouble connecting Panasonic TH46PZ80U TV with Sony DVP-SR320. Component Input No.1 and 2 will not recongize Sony DVP SR320 DVP Player. It will work when i connected to Video No. 1 Input. As i...
1) you must read the instr. manual and see the connection diagram, and test the cables if are ok
2) proceed after your are shure and test the connector for dirty, oxide, and clean it.
3) if the problem persist you must call to the sony customer service, in order to provide assistance from ONLINE via chat or phone.
God bless you
Jul 12, 2012 | Televison & Video
There is no video output from my Sony DVP NS51P dvd player though audio output is there.
Im guessing your connecting via a scart lead..... Try swapping the cable ends round so that the DVD end goes into the TV and visa versa.
Mar 23, 2010 | Sony DVP-NS51P DVD Player
I have a black screen on my sony dvp fx 720,sound is ok and the connection to the tv works fine.
pls.post me the solution for my dvd player on which the screen is black sound is ok and the connection to the tv works fine.my email address . pp2240@yahoo.com
Sep 07, 2009 | Sony DVP-FX720 Portable DVD Player
No suround when watching tv with sky + box,
You will need a DVD player with an optical output, as the sky engineer said. A Co-axial S/PDIF output could also work if your surround sound has that input, however not all units transmit surround encoded sound through the Co-Axial output. Only option really is to upgrade if that doesn't work
Mar 05, 2009 | Televison & Video
Buzz in Samsung Digital when DVP-NS57P Sony is played back?
Greetings,
Check the audio connection, the port on the TV might be grounded.
While playing, try moving the connection in the port.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 08, 2008 | Sony DVP-NS575P DVD Player
Televison & Video Logo
50 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
