Question about Dell Computers & Internet
Dell HP GSA-H60L 16X LIGHTSCRIBE MULTI DVDRW DRIVE
sandrew
  • 2961 Answers
SOURCE: problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Posted on Jun 13, 2007
  • 476 Answers
SOURCE: No Lightscribe
This could be a driver issues or is it software .
Remove device and software first reboot then reinstall
if you have the disk then reinstall should be straight forward.
Try plugging in the device ,
and use the device manager for the drivers update install.
(while in device manager-select device rightclick and update)
This should fix your issue,
If problem persists,
refer the problem to the retailer you purchased from,
should be still under wanrantee if its a new one,
there supplier should honor the warantee no problems....
You may need to provide proof of purchase for warantee.
Posted on Jul 19, 2008
Tualiapz
  • 80 Answers
SOURCE: My HP GSA-H21L lightscribe burner drive will play
There was a known problem with the firmware of HP GSA-H21L lightscribe burner where it will read CD and not DVD.
You can try upgrading the firmware from the link below (note: this is for DVD-RW 16X HL-DT-ST DVDRRW GSA-H21L)
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=pv-41633-1&jumpid=reg_R1002_USEN
If that does not work, you will have to talk to HP support and get it replaced.
Please rate this if it fix your issue.
Posted on Jun 05, 2009
  • 37 Answers
SOURCE: LG GSA E 40 L External dvd writer not recognised
you may be having conflicts with usb devices. try temporarily removing all unnecessary devices from the usb ports. unplug and then plug the drive back in. you could try another port. if all ports are in use, then unplug another device, like the mouse and plug in to that port, then plug the mouse into the writers port. i had a similar problem with a wireless usb lan that stopped another device from being recognised. when i removed the lan and replugged the unrecognised device, windows recognised it. i obviously had to use the wireless lan, so i swapped that with the mouse and it worked.
Posted on Jul 19, 2009
parrotheadpc
  • 2600 Answers
SOURCE: My DVD drive (Dell GWA-4164B HH 16x DVD+/-RW) will not read DVD's
click on the below link and download the avs dvd player...it is free and a great universal player.
http://www.brothersoft.com/avs-dvd-player-free-44678.html
Posted on Oct 11, 2009
Does this product have a cd-rom drive?
Yes it does.
SuperMulti 16X DVD(+/-)R/RW 12X RAM (+/-)R DL LightScribe SATA drive
For a full specification go to this WEB site.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=3688715&prodTypeId=12454&prodSeriesId=3688715&objectID=c01374065
Jul 07, 2011 | HP Pavilion Slimline s3400t, Intel Core 2...
Missing Drivers for LG GSA-60L Dvd Burner.
Google (or other search) LG GSA-60L Super Multi DVD Burner + drivers -- then go to the website and usually you can download them if the unit is reasonably recent.
May 13, 2010 | LG Electronics GSA-H42LK LightScribe 18X...
I need an internal plastic part for my hitachi GSA-H60L DVD burne
Unfortunately, you'll buy a whole one to get a piece of one.. If this is a PC mounted unit, look for a PC recycling center near you.. you may get lucky there, Fry's electronics sell internals for about $50.00, externals for < $150.00, Blu-Rays.. the latest, are still running at about $200.00.
Toby White-Beebe
Dell Certified Lead Systems Expert
Aug 28, 2009 | Compaq Computers & Internet
I can't print label to cd dvd from my dvd unit
Before you can use a lightscribe facility, you must have 3 things, which are, A DVD Drive thats has a lightscribe capability/function, a lightscribe software, and a lightscribe compatible CDDisk.
From what I can see, your drive is not capable, or does not support lightscribe functionality. I tried to check everything about your system model and I discovered that the capability of your DVD Drive is this :
  • Writable DVD formats: DVD-R (6x, DL [double layer]), DVD-RW (6x), DVD+R (DL [double layer]), DVD-RAM
  • CD formats: CD-R (24x), CD-RW (16x)
Which means your DVD Drive does not support Lightscribe facilities.
You can also check everything about your system from this link :
http://gdgt.com/toshiba/satellite/a305-s6857/specs/
Hope this helps you out.
Jul 13, 2009 | Computers & Internet
My HP GSA-H21L lightscribe burner drive will play a CD but doesn't read a DVD nor will it burn a DVD. Don't know what the problem is but sure would like to! Can someone help? Dee Nickens
Jun 04, 2009 | HP Computers & Internet
GSA-T40L Lightscribe Error
Try a firmware upgrade by downloading it from the internet but make sure the serial numbers match exactly. If that fails then it my need replacing.
Jan 09, 2009 | Computers & Internet
HP dvd740i DVD+- 16X Double-Layer LightScribe Drive
Your response quoted the "WRONG PROBLEM" that I had asked assistance
to fix
Jul 05, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Computers & Internet Logo
    67 people viewed this question
    Alun Cox
