Question about Drills
24 volt worksite cordless drill wont charge have a bad battery need to know what brads will work or where i can buy a 24 volt worksite battery
All info will be appricated
4 Suggested Answers
  • 103 Answers
SOURCE: HOW DO I KNOW WHEN BATTERY IS FULLY CHARGED?
you can chack that with a omes meeter ,,,or one hour of charging is plenty , cheers
Posted on Apr 12, 2009
RonPark
  • 855 Answers
SOURCE: where can I buy another battery
Could not find one listed in the stores. You can call 1-800-248-6657 and you need part #JDB240R I'm not sure of the price but with the difficulty in just getting a battery depending on the price you may be better off purchasing a new drill.
Posted on Sep 30, 2009
  • 49 Answers
SOURCE: Interchageble cordless batteries
not likely most batteries may look similar, but will not fit in the wrong device. Also if it did fit it would burn up your motor quickly. is there a problem with the 18v set-up?
Posted on Nov 16, 2009
I need to know what the output needs to be on the charger of an 18 volt jobmate cordless drill.
During the initial state of the charge, the charger operates in a fixed-current mode. This means that the current will be held at a constant rate until the battery is charged to a bit over 18 Volts. During this phase, the output of the charger will not be 18 Volts. This is done for safety and battery preservation; forcing 18 Volts on a battery discharged down to 15 Volts or less could cause the battery to overheat. If no battery is connected, the charge controller may hold the output low until a battery insertion is detected.
The exact behavior of the charger depends on the chemistry for which it is designed, whether Nickel-Cadmium, Nickel-Metal Hydride, or Lithium ion. If the output of a known-good battery is 18 Volts after charging, and it has normal capacity, the charger is working properly.
However, a bad cell in the battery changes things. If you run a Ni-Cd battery down too far, the weakest cell in the battery may begin to reverse charge from the current coming from the other cells. This usually causes an internal short circuit, and the cell will be stuck at 0 Volts. A battery pack with one shorted cell will read 16.7 -16.9 Volts when fully charged, and the drill will not have the peak power it should. The charger will give you a battery fault indication if it is equipped to do so.
Jul 08, 2017 | Drills
Where is the battery in 8 volt cordless drill
Did you give enough time to it to get fully charged before tring to work? It needs time.
Mar 02, 2015 | Craftsman 192 Volt Cordless DrillDriver...
I have a dewalt 24 volt sds drill when attach the fully charged battery to the body nothing happens when i remove the battery from the body it starts to smoke
So what is your question. It sounds like you have a bad battery so try it on another tool. If it works then the drill is not working or assembled properly if the same thing happens then you have ruled put the drill and there is a proplem with the battery
Mar 03, 2013 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
Need a battery charger for the 21.6 volt battery
It will work if it is of the same charger/receiver style. The only issue is that you will only be charging to 19 volts and not 21.6, I would estimate by doing some simple math that you would lose about 6-8% of the batteries capacity but you would be able to use it.
Jun 05, 2012 | kawasaki 21.6 volt Cordless Drill Driver 2...
I have a B&D 24 volt drill/ flashlight/ skill saw combo, reciently either the battery or the charger is bad, I put the battery in the charger an the light on the charger flashes (even when unplugged)...
If the charger is lighting up its probably the battery. Rechargable batteries have a lifespan governed by the number of charges.
The only sure way of knowing is to have another battery or charger that you know does work.
if it is the battery its normally cheaper to buy another complete drill.
Sep 13, 2011 | Black & Decker Black And Decker FS24C...
Trying to find battery and charger for Worksite Cordless Drill, Circular Saw and Lamp (flashlight). Model nos. on all state CT120-C. Voltage is 24 volts. Made in China. Can you provide any help on find...
I also have the CT120-C set, with the 24 V battery, but alas no charger. Been searching web with no luck. Have you found any links where you can buy it? If so, please let me know at gurven@gmail.com...
Aug 04, 2011 | Vacuums
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Apr 09, 2009 | Black & Decker Drills
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
