Question about SanDisk Sansa Fuze MP3 Player
Sansa Fuse Error 10 Firmware issue
Cannot get the firmware to load or computer to recognize the device.
Ran registry cure and SM registry check...NG
Fuze syns to laptop and office PC, not home PC.
Driving me nuts, any ideas?
Thanks Rockrico
You're havoubleshooting. i had the same problem. you'll need to contact geek squad and they will fix your computer to where whenever you plug in your sandisk rhapsody will pop-up. it will cost like 30$
Posted on Jan 10, 2009
My computer does not recognize my sansa clip
font.f1 {font: 12.0px Times} Hello and thanks for contacting FixYa Technical Support.
Anytime there is an issue where your Sansa clip is not recognized by your computer, run the firmware update for your version of Operating system (Windows, Mac or Linux)
Firmware is software for the hardware itself, so if there is a case, where the hardware connecting via a USB port like your Sansa clip is not recognizing, going to the manufacturer's website and updating the firmware for their specific product you purchased, is a step in the right direction.
For your benefit, I have provided the link to the Sansa Support page, where you can download and install the most current firmware update for your Sansa Clip.
Download Sansa Firmware Updater
Also, for regular operation of your Sansa clip, make sure you are following these steps for use of this device:
  1. Turn on the Clip
  2. Put the device in Hold (move Hold button until orange is showing)
  3. Press and hold the Center Button
  4. Plug the mini-USB connector into the device (be sure the USB is plugged into the computer)
  5. Wait for the Clip drive to mount
  6. Follow instructions below and drag files to the Clip drive
Let me know if this helps.
Regards,
-Mactechtrainer
Apr 28, 2010 | SanDisk Sansa Clip MP3 Player
Not enough mem to load music db
Generally the solutino for this is to reformat the player.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jan 23, 2009 | SanDisk Sansa Clip MP3 Player
Sansa e260 says connected but device not recognized
Substitute REC fo volume + in the following:
-Tha Mp3 Doctor
Nov 16, 2008 | SanDisk Sansa e250 MP3 Player
Computer won't read mp3 player
-Tha Mp3 Doctor
Sep 05, 2008 | Audio Players & Recorders
Computer wont recognize device
Your computer may not be compatible with the software on the installation CD - check Sandisk's website for a more up to date version of the software. Many, many, many products are not and never will be compatible with Windows Vista.
If it is DEFINITELY not an incompatible operating system, then:
-Tha Mp3 Doctor
Jun 30, 2008 | SanDisk Sansa Clip MP3 Player
Main image failed
Download the Sansa Recovery Tool from Sandisk's website
-Tha Mp3 Doctor
Jun 25, 2008 | SanDisk Sansa e250 MP3 Player
Can install mass storage device
-Tha Mp3 Doctor
May 22, 2008 | SanDisk Sansa m250 MP3 Player
Loading problems
-Tha Mp3 Doctor
Apr 19, 2008 | SanDisk Sansa e200 MP3 Player
Cyclic Redundancy Error
-Tha Mp3 Doctor
Dec 04, 2007 | SanDisk Sansa m230 MP3 Player
Malfunction
-Tha Mp3 Doctor
Dec 01, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa Fuze MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
