Question about Husqvarna Rz4623 46" Ztr Lawn Mower Zero Turn 23hp Kohler Engine
Won't move zero turn
Will not move. tried to purge air with no success. 14 hours on unit.
2 Suggested Answers
SOURCE: my viking #1+ embroidery unit when i turn it on the arm won't move to line up to embroidery
it would be a good idea to have the machine checked
Posted on May 17, 2012
Toro zero turn 52" commercial won't move but I can
is that push it around in your shop?
Apr 11, 2013 | Garden
1993 Oldsmobile cutlass ciera is stalling and won't restart after engine is turned off
Two thing, maintenance will be first[tune up,fuel filter,air filter].Second could be crankshaft sensor.
Mar 14, 2013 | 1989 Oldsmobile Cutlass Ciera
When i turn on my spa and heater it states on the outside unit "no air flow" and it won't heat up
that is usually an indicator of water flow not the air flow.
What does the hot tub do when you turn the breaker from off to on?
does it run through the purge cycle?
is it kicking out the GFCI?
if it is not tripping the GFCI then you most likely have either too little water flow for the heater to kick in or not enough water flow to activate the heater.
Try taking out your filter and see if that solves the issue.
you may also have a bad temp sensor if the tub just runs and runs but never heats up.
Rod
US Parts Center
888-521-6183
Feb 08, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How can I move my exmark zero turn lawn mower when it won't start?
on the rear of the machine there is a release lever for each side pull that back and down to lock it in place
Jul 12, 2012 | Garden
York Air Conditioner unit doesn't turn on
jumper red to yellow on thermostat if it kicks on problem is in the thermostat.
Apr 22, 2012 | Heating & Cooling
TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Apr 13, 2012 | Toro 60'' Zero Turn Lawn Mower Enclosed...
Error 6C10 keeps coming up on my Cannon Prixma ip3600 and it will not print. I had a look at a few other blog posts and tried a reset using the power and reset button, but no koy. Any ideas?
6C10 error (valve cam sensor error) is a mechanical problem in the purge unit area where the valve cam sensor is located (on the purge unit just behind the power switch button). On my experience, the movable gear assembly (with spring on top) can't move downward to move the other gear that is connected to the valve cam therefore the sensor is not sensing any movements.
Solution:
1. Open the entire top cover.
2. Locate the purge unit (the area where the ink carriage rests when not in use).
3. Move the carriage to the middle of the printer to access the purge unit.
4. Try to gently move the gear assembly downward using your finger or a screw driver to loosen the stuck gear.
5. Turn on the printer to test.
Oct 12, 2011 | Canon PIXMA iP3600 Photo Printer
Canon MP830 Purge unit sticking
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Husqvarna Rz4623 46" Ztr Lawn Mower Zero Turn 23hp Kohler Engine Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
