Question about Panasonic Combination Convection/ Microwave Mw Oven Circular Heating Element 120v 1200w
Oven door is misting up in between the glasses on the door, is this a problem
The Panasonic combi works well, but when using the glass door is misting up this is between the glasses wondering if the is a major problem and I should replace thanks
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Glass plate and int light failed - is this a fuse fail ?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Posted on Dec 07, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Glass panel shattered in door - NN-CT766M
In the US, we can order individual parts, and it's economical. You'd have to check the UK site to see if you can.
Panasonic's UK site is here, and you can use the support links to find spare parts and servicers.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Dec 25, 2008
  • 2692 Answers
SOURCE: Cracked door on Panasonic S753 combi microwave oven
No not dangerous because the shape of the metal is what keeps the microwaves in , not the door. Yes if you could get a door you could change it yourself.
Posted on Jan 08, 2009
flsty
SOURCE: I need a new door inner glass for Panasonic NN-A772SBBPQ microwave/combination oven
Think about calling up the Sears 800-4MY-HOME line... the parts dept can look up your model with the LIS and have the part sent to your address and a Tech to install it for you if you don't know how, plus if you do pay for a tech repair for like $40 they do a clean and prevenative maitnence check on any other appliance you may have thats acting weird.
Posted on Mar 07, 2012
Panasonic inverter microwave combi makes a clunking sound after a few seconds and the plate does not revolve properly, the supplier said it was burnt on food on the spindle but how could food get there, I...
Check the glass plate lines up with the 3 notches on the spindle, if it's not sitting correctly it will clunk, it's just a matter of getting the plate to sit right on the spindle, if still no joy check to see if the spindle is damage or the glass underneath.
Nov 23, 2013 | Microwave Ovens
Glass turntable in tricity tmc209 says "microwave only" What do I use for convection or combi cooking? Does turntable still need to rotate for convection cooking?
definately dont use the standard glass plate for convectional 'oven' cooking, as it will shatter. i have had TWO plates shatter so far before realising they should only be used for microwave cooking.
Aug 15, 2010 | Microwave Ovens
My Sylvania micro/convec oven was installed in my RV last year but has never worked correctly. It runs long after the beeping ends and the glass sometimes gets a rainbow haze across the glass. Is this...
With this oven being a combi ventilation and extraction is important, the haze across the plate is
surplus heat, It not cooking but what you hear is the extraction fan running until the oven cavity has cooled down
Feb 12, 2010 | Sharp R-353 Microwave Oven
How to replace door handle?
The door handle can easily be replaced. This is a common problem with microwave oven doors.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
Jul 30, 2009 | Microwave Ovens
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can i replace a broken door handle?
Yes. This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Jan 07, 2009 | Panasonic NN-S753 Microwave Oven
Broken door hook
The plastic cover on the inside of the door is purely push fit.
To force it off I used 2 strong stainless steel dinner knives.
By easing one knife between the internal glass and the plastic cover I managed to spring one corner by using the other knife on the external bottom edge of the plastic cover.
Try concentrating on one end and once this springs out it is easy to free the rest without having to take it off completely.
The hook is simple to do but be careful with the spring.
All in all it took 3 minutes!
Jan 13, 2008 | Neff B7740N0GB Microwave Oven
Panasonic Combination Convection/ Microwave Mw Oven Circular Heating Element 120v 1200w Logo
60 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
