Question about KitchenAid Architect KBRA20EMSS Bottom Freezer Refrigerator
Ice maker continualy runs even when ice tray is full
The ice maker will make ice when we empty the tray - runs every 2 minutes - hums for 15 seconds, then shuts off 24/7.
  • 2 more comments
  • mel_gillen Jan 11, 2009
    The water valve for the ice maker is what runs every couple of minutes. The machine is producing ice as normal, but this occurs even when the ice tray is full. It's not filling with water because it's already full with water. It's just operating when it shouldn't be. Thanks!
  • Ron Coons
    Ron Coons May 11, 2010
    ???? the ice maker continiusly cylces every 2 mins??? it takes 2.5 hours to normally cycle. when its "humming", isit ifilling with water???
  • Anonymous Mar 17, 2014
    how do i proper place ice tray in ice maker
  • Anonymous Mar 31, 2014
    ice maker does not shut off
    President:
  • KitchenAid Master
  • 2,651 Answers
Theres aproblem here, I dontquestion that your hearing something operating, but if the valve is being activated, its going to fill with water( thats what it does!) so if your not geting water every few minutes something else is"buzzing"i would look elsewhere fro your problem doesnt sound like the valve
Posted on Jan 11, 2009
How do I run diagnostics on a Frigidaire Gallery Refrigerator
Ice Maker (Flex Tray Fresh Food Compartment)
The Ice Maker must be turned on before entering the
Service Mode. Check the 'ice off' indicator on the User
Interface to verify that the ice maker is in on.
Diagnostic Service Mode Activation
Express-Select ™
To activate the Ice Maker Service Diagnostic Mode,
press and hold fresh food and freezer up (?)
simultaneously for up to ten (10) seconds.
Pro-Select ™
To activate the Ice Maker Service Diagnostic Mode, press
and hold 'options' and 'power on-off' simultaneously for
Activation of Ice Maker Service Diagnostic Mode
automatically turns off all Ice Maker Control PCBA
outputs. The compressor runs at fixed speed of 4500
rpm and the condenser fan turns on until Service Mode
is deactivated. The damper is closed and the fresh food
and freezer lights are enabled as well as the alarm audio.
Defrost of the main system is not allowed.
Deactivation
Express-Select ™
To exit service mode, press and hold fresh food (?) for
up to 10 seconds.
Pro-Select ™
To exit service mode, press and hold the (+) key for up
to 10 seconds.
Service mode is also automatically deactivated after 5
minutes of no key entries (that includes Communication
Lost). All outputs are turned Off. Previously selected
main system and ice maker operational modes are
restored.
Testing
To actuate an ice maker load of the selected test step
(turn on or off), use 'power on-off' on the user interface.
To step to the next ice maker sequential test, press fresh
food (?) or '+' on the LCD screen. To step back to the
previous ice maker sequential test, press fresh food (?)
or '-' on the LCD screen. The selected test number will
be displayed on the fresh food display.
After pushing 'power on-off' to start automatic test
or turn on the load, the ice maker control will display
the test result on the freezer two digit display. When
waiting for the test to be automatically performed and
the result displayed, the test number (test ID) will flash
on/off. After the automatic test is completed the test
result will be displayed as "P" - pass, or "F" - Fail.
For an interactive test, the technician manually activates
the load using 'power on-off' and physically verifies the
system response. Pressing 'power on-off' again turns
the load off. The freezer display shows the current or
expected state of the load. During the load transition
the fresh food display flashes the test ID. After the last
test step in the ice maker test sequence is completed,
the next advancing action will scroll back around to the
first ice maker test. Stepping back from the first test, will
scroll the test sequence backwards to the last test in the
sequence.
Note: The only test that the test number will flash during
the test is the bail arm test.
Note: If you advance to another test before the present
test is completed the ice maker will continue to run until
the tray reaches the home position before the next test
will start.
Service Diagnostic Mode Test
Sequence
Test 52C: Ice maker Thermistor Test.
The current Thermistor temperature is displayed on
Freezer display when the test is started. It will show the
temperature at the ice maker if the thermistor is good.
A "OP" will be displayed for open and "SH" for in short
circuit condition of the ice maker thermistor.
Test 55C: Water Valve Test
NOTE: Prior to initiating this test, verify that the ice tray
is empty. If not, empty the ice tray to prevent water
from overflowing into the ice bucket. To empty the ice
tray, remove the ice bin, place catch pan under the ice
tray and initiate test 63C. The tray will twist and empty.
Touch 'power on-off' to start the test. The lower control
board will turn on the green and brown water solenoid
valves for a duration of 4.6 seconds if set for small cubes,
5.8 seconds if set for medium cubes or 7.0 seconds if set
for large cubes. Additional 'power on-off' activations are
ignored. If you want to re-run the test you will need to
advance to another test and then go back after you drain
the water out of th
Jan 16, 2017 | Refrigerators
Igloo countertop ice machine says tray is full when empty and will not make ice
Hi I had the exact same issue after about a year of running my igloo ice maker non stop. To fix it I held in the on/off button and select button at the same time for about 30 sec and TADA!! Back to making ice.
If that doesn't work I've also read to leave machine unplugged for 6 hrs and then hold in on/off button for 10 seconds. Good Luck!!!!
Sep 13, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Samsung RF265 no longer makes ice. What might be wrong?
I have seen some very helpful info here and agree with those who are helping. However, if none of these ideas work, I have one more that I have seen work many times on new and even really old icemakers. Anyway, take out icemaker. Take cover off the icemaker that will expose a gear or two. VERY CAREFULLY turn the large gear just a half a tooth distance. If it will move a full tooth distance that's okay but don't get too tough with it. Put the cover back on, re-install, make sure the icemaker is plugged in good, arm is down in the "making ice" position and that the water is on. Then leave it completely alone over night and see if you have ice in the morning. Sometimes the motor that drives the harvest cycle gets "stuck" for lack a better term and works fine after that. I have done this with my personal icemaker a couple of times over the last 15 yrs I've had it. Repairmen will never do this or tell you little secrets like this because they don't know or don't want a second call if it doesn't work so its best for them to just sell a new one. Good luck!!! Mr. FIXIT retired appliance repair for over 35yrs.
Mar 27, 2015 | Samsung RF265AA Bottom Freezer French Door...
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
My srf7520ss is not making ice
These fridges are renowned for this problem & even Samsung seem to not know the answer. BUT I DO & WILL SHARE.
I was about to replace the ice maker, as that is what everyone seems to recommend. BUT being a skinflint & a why is it so person, I decided to do some logical fault finding first.
There is this thing called fuzzy logic & these ice makers need to know you are using lots of ice, so as to make more.
I found that emptying a near full ice tray into a plastic bag & putting this bag in the freezer, the ice maker would not necessarily make more ice! If it did it was very little.
A few days of this & I decided to operate the ice discharger motor for like a minute & a half when the ice tray was empty.
Within 10 minutes one could hear water being loaded into the ice cube maker. Some time later the cubes being dropped into the tray & the filling/discharging process repeated, until next morning the tray was near full again.
In summer [like now, with our very hot 30*-38*C [90*-100*F] weather] I do this, all the time, so as to ensure we always have plenty of ice. Works everytime.
Away for an extended period, as we are often the tray will fill then no more [or turning off the ice maker while away] & the ice maker won't get back on track until you do the above.
Mar 17, 2012 | Samsung Refrigerators
Every 15 seconds the refrigerator beeps and i noticed the refrig light was out. I replaced the bulb which is now working but it still beeps every 15 seconds. tThe temperature in both the frig and freezer...
I don't know if you have an ice maker but when my ice dispenser is full my fridge beeps because the ice can no longer go into the tray because it is full so I have to empty the tray. and the beep stops it also beeps when the water filter needs changing. I hope this helps
Feb 23, 2011 | Refrigerators
Ice maker is not working but water dispenser is.
Try the following check:
First make sure that the temperature in the freezer is 5 degrees or below.
Self-Diagnostics
Unplug the fridge and then plug it back in.
If the compressor is running when you unplug it make sure that you wait 15 minutes before you plug it back in.
You will then have 60 second to open the freezer door and 2 second to view the LED output code.
Ice maker check 3 pulses pause 3 pulses
Optics receiver 4 pulses pause 4 pulses.
Optics emitter and receiver 2 pulses pause 2 pulses.
All good 5 seconds on
Dec 28, 2007 | Whirlpool ED5SHAXM Side by Side...
KitchenAid Architect KBRA20EMSS Bottom Freezer Refrigerator Logo
132 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
