Question about Fahrenheat Heating & Cooling
How to wire 2543nwc baseboard heater with single pole fta1a thermostat
Paperwork not clear. got it wired but it seems too hot
3 Suggested Answers
hotuna
  • 288 Answers
SOURCE: How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Posted on Mar 20, 2008
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
Cadet baseboard heater
If I have your information right you have a black wire and a white wire marked red coming to the heater with 240 volts between them. You have a double pole unit mounted thermostat with a red and a black wire. Most double pole thermostats have two red and two black wires on them so I am not sure if you have a double or a single pole thermostat.There are also two wires going to the baseboard heater. One is connected to the element the other to a high limit switch which is then connected to the other end of the element. If the thermostat is a double pole the two red (or load) wires should connect one to each of the baseboard wires. The two black (line) wires should connect one each to the two incoming power leads. If it is a single pole thermostat the one red wire should connect to one of the baseboard wires the black should connect to one of the incoming power wires the remaining baseboard and power wires should then be connected together. Hope this helps
Dec 12, 2013 | Heating & Cooling
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Jun 21, 2011 | Heating & Cooling
Bought a Fahrenheat 5' baseboard heater and a single pole thermostat to replace an old heater. What's the difference between a single and double pole thermostat? Which should I use? I have a 240v line...
Here is a link to the wiring instructions, which has detailed pictures and instructions. This should make it a lot easier. http://www.marleymep.com/en/multimedia-library/pdf/fahrenheat-pdf/products/f2500-series/F2500wiring.pdf
Feb 14, 2011 | Fahrenheat F2545 Electric Baseboard Heater
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
I can not figure out the wiring for my thermostat. this wiring diagram is worthless to me. I have a fahrenheat single pole thermostat model fta1a. Where do the wires from the breaker box go? It almost seem...
do not purchase Marley Fahrenheat products as they refuse to provide useful installation directions to the home owner. return product to store for a refund in protest of their totally bogus installation directions total junk thanks for wasting my time. I will be sure to smash it before I return it to the store to show my gratitude for the waste of a time web site!!!!!!!!!!
Dec 21, 2009 | Fahrenheat Built-In Baseboard Thermostat...
I need to know how to wire the thermostat to the 30" Fahrenheit baseboard heater
if its 240v your line in to the thermostat is two hots (black and white, white in 240 is no longer nuetral and must be marked as hot) and a green/bare ground from the panel, these usually connect to the reds on the double pole thermostat. the load out is usually two black wires which are then connected to the black and white wires of the baseboard unit.
Aug 21, 2009 | Marley Heating & Cooling
Dimplex baseboard heater wiring
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
65 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
