Question about RTO Image 15.0R Treadmill Walking Belt
IMAGE 19.0 R treadmill
The console lights up but the treadmill will not start. The incline only goes up about a quarter of what it should. The fan and the heart rate monitor work good. This treadmill has 35 miles on it. Help. Thanks.
    Top Expert:
  • RTO Master
  • 12,223 Answers
1) Adjust the REED switch, clean it, and tight the plugs or connector very well, see the diagram
2) LUBE the deck belt, this could be happen to due the lack of maintenance, you must do it every weeks of use, use 100% silicone LUBE, and do it.
3) LUBE the rollers bearing with DW-40 with small quantity.
3) Tight a little drive belt motor, and replace if necessary, the tension must be 1/4" of flexibilit.
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubleshooting motor.
5) Test the output voltage board, for input voltage motor, if there are NOT voltage, the board is faulty.
see the block diagrams
God bless you
Posted on Nov 26, 2012
Lights up, start does not start on console, belt won't move , decline , incline does not work, age goes down but not up, speed does not work...pulse on handles work,,,
Do you have the iFit component on your treadmill? We had a similar issue and I unplugged the iFit component (requires opening the console and unplugging the ribbon cable that attaches the iFit component) and the treadmill started working again.
Jun 08, 2014 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
Image 17.0 Treadmill is stuck in incline position and will not go down. I do not plan to use the include at all, is there a manual way to move the incline to 0? Any suggestions?
Hello there, The first thing I would try is to calibrate the incline on the unit.
Do this using the following procedure.
With the safety key out, press the stop button along with the speed up button while inserting the safety key onto the unit.
remove your fingers from all buttons, Then press the stop button one time. Now press the incline up button one time.
The unit should go all the way to the top, then return to the bottom.
Remove the safety key and reinsert it to continue using the machine
If this does not work you can manually move the machine to the bottom using this procedure.
Remove the hood cover b removing 2 screws in the rear of the machine and removing the first 2 screws on the foot rails on each side.
You can now lift the cover out of the way.
At this point you will see the incline motor located in the center of the unit pointing in a downward direction.
On the top of the motor there will be a small fan encased inside of a metal cover. There will be a flat head screw located inside the metal frame where the fan is. Rotate this clockwise to lower the unit. (the motor is geared very high it may not seem as though it is moving but it is) be patient that procedure does take a little while.
Any questions please feel free to leave another message on this link.
Good Luck! Tim
Jan 10, 2010 | Icon Image 17.5 S Treadmill
My treadmill's incline goes up and down but the treadmill will not start. What could be the problem?
The motor controller. If everything works but the belt will not turn, that's 99.99% your problem. I can get you a controller and walk you through replacing it. Otis@otisfitness.com
Nov 17, 2009 | Icon Image 17.5 S Treadmill
My console does not allow me to change the incline, speed, etc. The control panel does not acknowledge the buttons pushed. I've turned it off and on.
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Sep 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Image 10.0 treadmill incline not working
You have a stripped drive gear on the lift motor, order a new incline motor, install it and then calibrate it and you should be fine.
Apr 26, 2009 | Icon Exercise & Fitness
RTO Image 15.0R Treadmill Walking Belt Logo
243 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
