Question about G.E. Thompson RCA-25423RE1 RCA 4-Line EXP Speakerphone w/ Intercom
On my RCA model 25423/24 phone how do I transfer a call to an outside line
2 lines in use with no-one on them
This can happen if you transfer a call from outside to another outside line, or if somone has their phone set to forward to an outside line (like a cell phone)
Also, if you do not have "Disconnect Supervision" on your trunks and "Clear on Disconnect" (COD) set by the phone company, this can happen.
This sort of fix is usually done by a telephone professional, but you can do it if you specify the model number of the PBX that you have.
To clear the lines, you either need to reboot the PBX or temporarily disconnect the lines from the PBX.
Mar 21, 2011 | NorStar M7310 Corded Phone
Phone company added a dedicated fax line to the outside of my house and my home phone rings to my fax
Your wall outlet has four wires, the center two are the first line and the outside two are the new fax line. You need to go to Radio Shack and get an adapter to split your first and second line into two separate wires. The part number is below.
Steren® 2-Line 4-Conductor Splitter/Adapter (Ivory) pixel.gifModel: T07843 | Catalog #: 55034722
Mar 09, 2010 | Panasonic KX-FHD332 Plain Paper Thermal...
Automatic transfer to a mobile phone number
This question came up before and it works if you have a TA-824 as the system. http://www.fixya.com/support/t3120724-forward_calls_outside_number
The key is that you go to the intercom and dial 9 to get an outside line. If you get a line, you don't have to program 400 to disable the unused lines. After that, you enable outside line transfer, change the time for longer than 10 minutes if you need to, and dial the 7139 phone number # forwarding code.
Hope this helps. If you're using a different system and it doesn't, post back as a comment with your phone system model number.
Carl
Oct 18, 2009 | Panasonic KX-T7730 Corded Phone
Can I transfer voice messages to a cell phone
Yes and no (or maybe)
Your Norstar system is capable of outbound call transfers... transfers to people outside your phone system.
Most instances, the programmers shut off this feature of out bound transfers to protect your system from fraud.
A programmer will be required if you need this feature to work.
Otherwise, try this... outside caller calls in, (you want to transfer caller to a cell phone), press the TRANSFER button, pick an outside trunk (Line 2), and dial out, when you hear ringing, hang up.
The call will be transfered to the cell phone.
Aug 14, 2009 | NorStar T7316E Corded Phone
Can you transfer a call to an outside line on the
Trunk to trunk transfer needs to be turned on for this feature to work.
Dan
Aug 06, 2009 | AT&T Merlin Plus 820D2 KSU Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
How to configure call forwarding on RCA RCA Phone model 25425RE1-
CALL FORWARDING HAS TO BE DONE THRU THE PHONE COMPANY IF YOU HAVE CALL FORWARDING - AND I DO THIS IS WHAT I DO - I HAVE AT&T IN MEMPHIS TN PICK UP HAND SET AND HIT *72- YOU WILL GET A BEEP- DIAL THE PHONE # YOU WANT TO FORWARD THE PHONE TO - SOMEONE MUST BE AT THAT PHONE NUMBER TO ANSWER IT! ONCE THE LINE IS ANSWERED- THEY HANG UP AND THEN YOU HANG UP AND PHONE SHOULD BE TRANSFERED- I ALWAYS TEST IT TO UN- TRANSFER IT PICK UP PHONE AND HIT 73# AND IT WILL BEEP 2 TIMES- NOW PHONE IS NOT TRANSFERED ANY MORE
Jan 16, 2009 | RCA 25425RE1 Phone
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
Can I forward an incoming call to an outside line?
External transfer to Mobile 1. Transfer 2. press 1 and external # 3. Wait for ringing 4. press feature then transfer 5. hang up
Jun 11, 2008 | NEC Electra Elite 32D-1 Corded Phone
Transfer Calls
yes, but it has to be the same system or model and the way it works is , when you have 3 phones and you start to connect eachone then the 1st phone becomes the 1st extention and so on and so on with the other phones.
Mar 12, 2008 | RCA 25202RE3 Corded Phone
G.E. Thompson RCA-25423RE1 RCA 4-Line EXP Speakerphone w/ Intercom Logo
Top G.E. Thompson Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a G.E. Thompson Lands Phone Expert? Answer questions, earn points and help others
