Question about Emerson Lc320em1f TV
32'' emerson tv says digital telivision then nothing
First the standby light is on, then press power and then it says Digital Television then the power light and the standby light turn on and the screen goes black. Can anyone help me out?
    New Friend:
Press power screen reads digital television then the power light and stand by light turn on then screen goes black
Posted on Mar 20, 2013
dsacco86
  • 1077 Answers
SOURCE: When i turn the tv on it goes to standby right away
If not under warranty, here's what you need to replace inside your TV. Power supply board BA71F0F01042.
The board is hard to find right now. Only three places I know of to find it.
Ebay,
Discount-Merchant.com,
and Shopjimmy.com
Right now, only Discount-Merchant has one in stock. Here's the link:
Discount-Merchant.com - Projection LCD / DLP TV Lamps - Plasma ...
I know it would be cheaper to fix the TV, than replace it.
If you end up throwing the old board in the trash, I would like to keep it if possible. Here's my e-mail, dsacco86@hotmail.com
Posted on Apr 25, 2009
dsacco86
  • 1077 Answers
SOURCE: Emerson LC320EM82 S LCD TV I purchased this TV a
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Posted on Jun 18, 2009
dsacco86
  • 1077 Answers
SOURCE: my flat screen tv does not have a picture or
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Posted on Sep 04, 2009
dsacco86
  • 1077 Answers
SOURCE: I have a LCD Color TV, but when turn on, green
The most common problem is the Power/Backlight Inverter Board. There are 6 mini transformers on the board, one goes bad and the TV will turn itself OFF automatically for " Protection Mode". Replace the whole board or replace the bad mini transformer.
Part number#
Whole board, BA71F0F01042
Mini Transformer, LTZ2PC0MS008
Posted on Mar 02, 2010
  • 1684 Answers
SOURCE: emerson lc32oem8 32
The flashing power light indicates a failure in the power supply board of your tv. We should be able to repair the board for our standard rate of $45 plus return shipping. If you are interested in setting up a repair please use the following link to our web site: http://www.ccl-la.com/blog/index.php/service-request-form/ Our normal repair turn around time is 2-3 days.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Mar 08, 2010
Testimonial: "thanks!"
Emerson TV
Check capacitor on power board they must be changed 1st
Aug 02, 2016 | Emerson Televison & Video
Emerson TV wont stay on
you have to check the power supply of the tv. for the check the video to know how check the power supply of an lcd tv . if you need the circuit diagram of the power supply the link to it is also added
http://electro-medical.blogspot.in/2015/10/emerson-lc320em9-service-mode-how-to.html
Testing LCD TV Power Supply BoardsSTEP BY STEP
Nov 07, 2015 | Emerson LC320EM9 32 in. LCD HDTV
Can't find the codes for my emerson tv codes for
Instructions
    • 1Remove the battery cover and insert new batteries into the remote. Press the "Power" button on the television to turn it on.
    • 2 Press the "PRM" button that is in the lower left corner of the remote control. You should see the signal indicator light come on.
    • 3 Click the DTA800 TV Codes link in the resource section to view a list of program codes for the converter box. Enter the 3-digit code for your television by pressing the number keys on the keypad. Press the "OK" button when finished. You should see the indicator light turn off.
    • 4 Point the remote at the television and press the volume keys on the remote control. If the volume for the television changes, the remote has been programmed successfully.
    • 5 Enter another 3-digit code for your television if the first code fails to program the remote
    • CODES : Emerson
      • The RCA Universal Remote has 17 different codes for Emerson televisions. These codes are 011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064 065, 067, 075, 076 and 079. There are 18 different Emerson VCR codes. These codes are 008, 009, 010, 013, 015, 020, 023, 027, 034, 041, 042, 047, 057, 062, 065, 067, 068 and 070. There are no codes for Emerson cable boxes.
      Hope this helps. =)
Sep 30, 2014 | Televison & Video
How to determine if power board on emerson tv model lc320em1 is shot
The power supply regulator board to your TV is now working fine, and has no problems at all, as, there is standby light. Check all the other voltages comes out from the power board, to main board. If all of it found OK, the fault should be at its main board.
About blinking of standby/power light;
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Emerson Lc320em1 TV
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson Lc320em1f TV Logo
480 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
