Question about Home
Problem with water leakage at flapper valve on eljer toilet
Water leak at flapper. replaced flapper but still leaks. I assume there is a problem at flush valve . Where is the model # shown on the toilet. I find one # on underside of lid? viz; 1081377733 is this correct? This toilet was probably manufactured prior to 1992
    Top Expert:
  • 12,650 Answers
Recheck flapper may have replaced it with wrong one
Posted on Dec 04, 2012
4 Suggested Answers
  • 512 Answers
SOURCE: Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Posted on Aug 19, 2009
SOURCE: A small intermittent water leak in the flapper
1) If spud washer between tank and bowl is leaking, you will get moisture on outside of tank in that area.
Use dry paper towel and run around area for evidence of moisture.
2) The flush valve is sold separately for typical 2-part toilets. Sold at hardware/home center.
See image of product:
http://www.furniturefind.com/Fluidmaster-507C-FLM1009.html
3) Home centers also see spud washers for typical 2-part toilet.
You can use your old spud washer, and you can seal it during re-assembly using rectorseal
See image of rectorseal
http://www.fixya.com/support/r7929008-replace_garbage_disposal
4) 'water hammer' is when pipes make banging or rattling noise when faucet or valve is shut off.
Add air chamber to water line near faucet or valve.
Air chamber is 18" piece of pipe with cap that sticks up from water line.
Since water will not compress, shutting off flow of water stops forward motion of column of water causes energy to be dispersed into the pipes.
Air can be compressed. Adding air chamber is like putting shock absorber into water line, so forward energy of water harmlessly compresses the air for a moment.
http://www.renovation-headquarters.com/water%20hammer.htm
Posted on Mar 08, 2011
  • 413 Answers
SOURCE: I have an Eljer 141
I had one just like that where the overflow tube that the flapper connects to was cracked. It sounds like this is the only part you have not replaced. The flapper may not be seating onto the inlet either. If you replaced the flapper with a cheaper version of flapper, some new ones will even leak.
Posted on May 16, 2011
I have an Eljer 141 0220 toilet. The the tank leaks into the toilet and every so often the water runs to refill the tank. Initially, I replaced the flapper. That did not work. I then replaced the...
May 16, 2011 | Eljer 141-0220-00 Toilet Tank White
Eljer 0220 toilet leaks from tank to bowl, then fill valve spurts out water from top and around the edges, and also through the tube that goes to the overflow. Replaced the flapper, but still leaks. Also...
When the tank is full and leaking into the bowl reach in and put slight pressure on the flapper and if the leak stops then you may have the wrong flapper or the flapper is not installed properly. If that is not the case then make sure the flush valve seat is not cracked or that the surface is not warped.
Mar 05, 2011 | Eljer 091-0220-00 White Savoy Two-Piece...
Eljer runs constantly. Replaced the flapper to no avail. I can see the wate flow in on the right side of th bowl looking at the tank. Any suggestions?
The next thing for you to check is the fill valve itself, make sure it is shutting off. shut off the water to the toilet and see if the leak stops after a few minutes. it may also be a leaking gasket on the flush valve gasket. also be sure the flapper area is clean. hope this helps. let me know if you need anything else.
Jan 04, 2011 | Eljer Home
Leaks from tank into bowl and when flush as it
Change the flapper with a generic one that will fit that toilet... the OEM flapper is **** and it does not allow for a good flush either...
heatman101
Aug 03, 2010 | Eljer Toilet Onepiece Canterbury ...
Trickle leak refill 1-2 minutes city water 40 PSI
the flapper valve is a common piece to obtain and easy enough to replace..
Aug 02, 2010 | Eljer Aqua-Saver 12" Two-Piece...
I have one piece Eljer toilet, water tank is emptying. What do I do? It usually happens oner night.
flapper valve leaking check for build up or debris if clean check adjustment or replace flapper
Jun 10, 2010 | Eljer Toilet Onepiece Canterbury ...
Water leaks into the bowl through flapper. replaced flapper and it still leaks.
THE THING THAT THE FLAPPER SITS ON IS CALLED A DOUGLAS VALVE. EITHER SAND AROUND THE RIM OF THE VALVE WITH FINE SANDPAPER. UR TRYING TO REMOVE ANY IRREGULARITIES ON THE RIM OF THE VALVE. IF THAT FAILS TO SOLVE THE PROBLEM, TIME TO REPLACE THE VALVE.
Dec 18, 2009 | Eljer & Elongated Toilet Bowl
Water leakage from the gasket under the flapper
You will need to replace or repair with new gaskets your flush valve mechanism. "To do that you need to take the tank apart from the bowl. Have new toilet bolts and flush valve or flush valve gaskets at the ready when you take the tank off. (you will also have to unhook the fill valve when you take the tank off.) Another possibility would be a cracked tank that is causing the leak in that area but that is rare.
Oct 07, 2009 | Eljer 111-1000-00 White Kindergarten...
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Dec 21, 2008 | Home
Home Logo
321 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
