Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
Replacing both Drive belts on toro 832 snowthrower
Great machine! I bought it second hand but the owners manuel ignores the most important part...replacing the drive an auger belts! I now have the replacement belts but damned if I can figure out how to put'em on. I've taken off the bottom plates and the belt housing in front of the engine. That should be all as far as access but the drive wheels are so close together I can't "slip" the belts into place....help!
Ok I did it! First, remove the semicircular housing in front of the engine. This will expose the two pulleys. You do have separate the auger section in the front. There are four bolts (two on each side top and bottom) that secure it to the engine section. The bottom two are in slots so you only have to loosen them. Once the top two are out you just tip the handlebars back and they separate. What you end up with is a pulley on each section.
The larger of the two belts goes on the back pulley, pass the tension wheel on the inside before attaching to the rear slot on the engine wheel.
Attach the smaller belt to the pulley on the front section and then join the two sections back together making sure the belt passes it's tension wheel in the same configuration as the other. Then just screw every thing back together.
This is definitely a two man job as this is one heavy machine.
Posted on Jan 12, 2009
    Scholar:
  • 76 Answers
If you tie both the auger and the drive handles down that will give you enough room to get the belts out, and when you put the new belts on be sure to get the belts inside the belt guides otherwise you'll be replacing them again.
  • Mark Tripp
    Mark Tripp Jan 13, 2009
    I have a 1032 and I've done several belts on several different types of snow blowers and have not had to take one apart to change the belts yet.
Nee Elna Envision 8006 ownersw manuel
see if the link for a manual is the right one for the machine Elna 8006 Instruction Manual
Apr 19, 2014 | Sewing Machines
My Toro Z4200 will not turn when i engage gear on my right hand, machine sat all winter in my garage, replaced battery, which i can understand, but why did the hydro-gear on right side quit working just...
Make sure the hydraulic transport bypass is not open. It may be that your belt idler is sticking for the drive system. Check under the machine and see if all the belts are tight. You might need to grease the idler arms.
See a local dealer like www.arcolawn.com for diagrams and parts.
Good luck
Mar 13, 2011 | Toro Lawn Mower With Toro Power Tools
I need to replace the belts on my toro 828LE Powermax snowthrower
Well, this is a problem posted in the washing machine section, but this is your lucky day. Try this link. If you don't go directly to a manual for Toro 828 and 1132, join manualsonline.com and look through the outdoor living menu, snow blowers. if the link works, check out page 18. Good luck!
Feb 02, 2011 | Washing Machines
I am looking for the owner's manual for a Toro snowthrower CCR Powerlite 325E 38182
I think if you write the company and tell them your problem they will send you one. I wasn't able to find it either.
Good Luck,
Jim
http://www.toro.com/intl/ca_en/home/snowthrowers/gassinglestage/ccr325.html
Sep 09, 2010 | Garden
I have a Toro Proline walk behind . Problems with the self propel
I suspect the drive belt, not the Hydro. Especially if the drive belt was never replaced. The belts are known to stretch and wear out over time. It's a cheap part.
Jun 04, 2010 | Toro Lawn Mower With Toro Power Tools
How to change my rotor blade on my toro
Is there an easy way to install rotor blades on a Toro Model 38430 snowthrower?
Mar 03, 2010 | Toro Garden
How do I get instructions on replacing both upper and lower drive belts on a LX425 Toro Lawn Tractor?
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Oct 25, 2009 | Garden
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
235 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
