Question about NEC ETW 16DD-2 Corded Phone (necetw16dd-2)
Do not disturb button is on my nec etw 16dd 2 and do not know how to turn it off
4 Suggested Answers
SOURCE: nec etw 8-2
Try pressing 'FNC' 1 to turn the mic on
Posted on Oct 22, 2008
  • 63 Answers
SOURCE: Settings
If you have a nec electra elite system go to the operators phone and hit feature key then dial 9 #
Posted on Feb 16, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: nec etw 8-2 wont work at home?
Sorry, but there is no way to get this phone to work on your normal residential phone jack. It was designed to be used as part of a key system, which requires the control system (also called the KSU). The phones are a proprietary digital design and only work when attached to the proper KSU. Unless you want to try locating the rest of the system on eBay or purchase through some other vendor, all you can do with the phone is use it as a paperweight.
Posted on Mar 12, 2010
Why is my display is flashing "BATTERY LOW" where is the battery located?
Look on the bottom for a door to access the batteries. If all else fails go to the manual you received with the phone and follow its instructions.
Apr 28, 2014 | NEC Electra Professional Etw-16dd-1 /...
NED DTB-16D-1; how do i turn on the ringer?
THIS IS THE DO NOT DISTURB FEATURE, TRY SPEAKER + 42 OR SPEAKER + 41 THIS SHOULD WORK.
Jan 06, 2011 | NEC Electra Professional ETW-16DC-2
I would like to know how to program numbers and recall these numbers on my phone
The Buttons must be set up as speed dial in the PBX if they are then its a simple process
Mar 04, 2009 | NEC ETW 16DD-1 Corded Phone (necetw16dd1)
Settings
Feb 03, 2009 | NEC ETW 16DC-1 Corded Phone
I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Jan 06, 2009 | NEC Electra Professional ETW-16DC-2
I don't know how to use redial
The Last Number Redial feature is invoked by pressing the <LNR/SPD> button then the "*" (asterisk). This is true whether you have the NEC Electra Professional Level I or Level II system. To know what other features are available depends on the system. If you know where your main control box (KSU-Key Service Unit) is, the Level I system has a plastic cabinet, the Level II system has the metal cabinet.
Jan 02, 2009 | NEC Electra Professional ETW-16DC-2
How to activate mic phone
Feature 1 or function 1 will work
Mar 04, 2008 | NEC Electra Professional ETW-16DC-2
Nec etw 8-2
FNC 1 toggles microphone on and off on the ETW-8 phone
Jan 24, 2008 | NEC ETW 8-2 Corded Phone
NEC ETW 16DD-2 Corded Phone (necetw16dd-2) Logo
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
