Question about Intuit Quicken Deluxe 99 for Windows (quicken99)
99 Ford Taurus, Didnt start, jumped it, it sat over night and next morning same thing. Got the battery charged and a friend who is helping says there is a short somewhere because the battery was arking. what should i do?
    Champion:
  • Intuit Expert
  • 237 Answers
Replace the battery. If it is arcing, it has a plate shorted out and could explode.
Posted on Jan 15, 2014
New alternator and battery, but the battery is not charging so car dies and wont start what do I need to check next.
bad conection. need to change batt posts on car or it dont have a good ground. follow the neg wire n check that one too.
Mar 01, 2013 | 1997 Ford Taurus
Truck is draining charge and not charging battiers
I just went thru same thing with my 2003 f-350 diesel. I hooked up my horse Trailor and drove to Von's parked went in came back out and truck was dead. I tried to jump it didn't work. Then over next two hours two tow truck Drivers hooked up to both batteries full power charge direct to my truck and would not start.
End story required two new batteries alternator and cilanoid discussed above. In other post. Also contributing to the cause was really badly coroded cables they looked good at the connection point but wher discovered to be coroded inside the tubing just above the end connections so bow it has all been replaced and I have had no trouble since. Hope this helps. Tanya
Jan 23, 2013 | 2003 Ford F350 Super Duty DRW SuperCab
1995 Ford Taurus not starting. Sometimes it starts and sometimes the starter won't turn over not even a click. Wait half an hour and it may work fine. Starter less than a year old as is the battery
Even though new-ish, I'd still suspect the battery has no charge, ask a friend to give you a jump start. Then give your car a good run, 20 miles, if is doesn't work again the next day either the battery fails to keep its charge or the alternater isn't charging it. A good garage will be able to test either for you, you'll need to change the failing part.
Feb 17, 2011 | 1995 Ford Taurus
I have a 1990 Ford Taurus and the battery won't hold a charge it will if I jump it but is dead after sitting over night. How do I tell if this is the battery or the alternator, or is the fact that after...
you can stop by and auto parts store and they will check you charging system for free and let you know for sure if it is the battery or alternator
Aug 28, 2010 | 1990 Ford Taurus
My 99 taurus was running just fine. then the next
the battery light is on due to the engine not starting. there are too many things that could go wrong to diagnose without more info. does the it crank but won't start or does it not crank at all?
Mar 20, 2010 | 1999 Ford Taurus
Truck sat for 6 weeks battery went dead. Charged
If checking battery cables and wiring to the starter and ground points doesn't help. Have the battery checked for a bad cell. Preferably before you charge it.
Feb 16, 2010 | 2004 Ford F150
Battery wont stay charged
Your alternator may be going out, have it bench tested at a Checker's or Autozone to see if it needs to be replaced. If it's bad which it probably is, replace it, if not you may have draw on the battery.
Dec 14, 2009 | 1996 Ford Taurus
Saab 2002 9-3 se -- initial start ok, but later will not. here's the steps: 1] turn key - computer check completes - turn to start and nothing happens. 2] come back a while later and it starts, but later...
I have a 2001 saab 93 and battery will need a jump in the morning but battery is new. I found a small fuse box next to the battery with 4 60amp mega fuses in it and when I remove the 1st 2 fuses the battery will be ok in the morning? can someone help
May 06, 2009 | 2004 Saab 9-3
Computers & Internet Logo
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
