BLADES
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
SOURCE: band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
SOURCE: band saw ,blade length
The blade length used on the 9422 is 52.75 inches.
Please rate this solution on FixYa!
SOURCE: NEED BAND SAW BLADES FOR MY OLD BLACK & DECKER
sometime you can get lucky on ebay. thats one place you check. the best thing about it that it's nation wide. i found alot of odd items in there.
SOURCE: need blades for a black and decker band saw 7
You can det it @ www.grainger.com. hope this helps
The motor is AC (alternating current) and only runs in one direction. Therefore, the only way to reverse the saw blade direction is to flip the position of the motor 180 degrees. The teeth of the blade should be pointing down and face to the left when you are standing in front of the saw. The blade should travel down into the table so the blade pushes the work into the table. I hope this helps since it sounds like the blade may be installed incorrectly.
