Question about Mitsubishi HD1000U DLP Projector
PROJECTOR SHUT DOWN AFTER BULB REPLACEMENT
I have the older Mitisubishi HD 1000. I ordered a replacement lamp bulb 8, 9 months ago and waited until the oldone finally stopped working, replaced it with the new lamp, set the lamp timer (I ehink I did it properly) and it played for about an hour then stopped. Now nothing on the machine works or lights up, even the power on button does not come on or light up. Its like it is dead. So since the first lamp was only waranteed for about 90 days I had to order another lamp and I do not want to mess this or anything else, so my question is: Is there any thing I am missing in replacing the lamp? Is it proper for the entire machine to stop working when the lamp is dead? Can I test the replacement bulb in the machine to make sure it is the problem? Is there a reset button on the machine or ??? Anotherwards is it the machine acting up or is the replacement lamp faulty? All I really need to know is how to get the machine running again.I cannot afford to go through too many lamps at $300 a pop
Marrie
  • 563 Answers
SOURCE: The Protectiopn circut is working
Hi there
Did you check that your lamp hours were actually reset ?
Posted on Mar 27, 2008
  • 50 Answers
SOURCE: After replacing the lamp in
To reset the lamp operation time on a Mitsbishi XD480U:
Plug in the power cord, turn on the lamp, and press the Left Arrow button, Right Arrow button, and POWER buttons on the control panel ALL AT THE SAME TIME, holding them all down for about three seconds.
Notes:
•Unless these three buttons are pressed at the same time, the lamp operation time isn't reset.
• Make sure that the STATUS indicator is lit twice and the lamp operation time is reset successfully.
• The projector doesn't turn on if the lamp cover isn't attached securely.
• Be sure to reset the lamp operation time whenever you replace the lamp.
• Do not reset the lamp operation time unless you replace the lamp.
Posted on Dec 17, 2008
  • 50 Answers
SOURCE: What 2 buttons other than the Power button
Notes:
SOURCE: automatic power shut off
Hold right left and power all at the same time and it will reset...
Posted on Feb 28, 2009
projdoc
  • 2237 Answers
SOURCE: Projector suddenly shut down
you need to reset the lamp timer. turn it on, and press and hold the left arrow, right arrow, and power button until it resets.
Posted on Aug 04, 2009
The projector lamps always burning out. I think, the cooling system does not work?How does the projector work?
Make sure not to shut down the projector after use. Wait until the fan stops. The fan is to cool down the bulb during and after use. Once the fan stops, then you can shut it down.
Feb 29, 2016 | Office Equipment & Supplies
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
WHY DOES MY HD OPTOMA DLP 70 TURN OFF AFTER FEW MINUTES?
If you have recently replaced the bulb you may need to reset the lamp counter in the projector menu.
If you have not replaced the bulb, the projector may be shutting down due to over-heating. Check that the projector is clear of as much dust and debris as possible.
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
When i turn on my projector it stays on for a few seconds
On your Cinego remote, push the setup button (bottom row, second from the right). Using your number keys and their corresponding arrows (7, 0, 9, 5), move to management, and then down to "lamp reset." Push enter (8) and follow the prompts. Always be sure to use Economy Mode (top of the management list) each time you turn on the Cinego to drastically increase your lamp life.
Jul 06, 2009 | Radio Shack Cinego D-1000 Multimedia...
Panasonic lamp
Brian, I just helped my buddy replace his Panasonic ty-la 1000 bulb this weekend. I have to tell you that I have a complete illiteracy when it comes to electronics but we got it done in about twenty minutes and were watching it again. Looks great. We ordered the bulb from dlp lamps.com and had it in about two days. They also had super easy instructions to follow. Try it before you replace the entire TV.
Sep 07, 2008 | Panasonic TY-LA1000 Projector Lamp for...
HD72I WORKS FOR 30SECONDS AND THEN SWITCHES OFF
I had the same problem with very few hours on the lamp. Sent it back to the factory and they said the fan was overheating causing the bulb to shut down. They replaced the fan and the bulb for free under warranty. I noticed before I sent it the projector was putting out an incredible amount of heat. MUCH better after fan replacement.
Aug 27, 2008 | Optoma HD72 Multimedia Projector
Projector Doesn't Power-ON
Hi bmosai
Yes you will have to replace the lamp.
The Projector will shut down and stay off as a safety feature.
May 04, 2008 | Panasonic PT L711U Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
CINEGO
Mine does the same thing and I just replaced the bulb after waiting almost 6 months and I purchased one directly from Radio Slack. It will turn on for about 10 seconds and then goes into shut down.....At three hundred dollars I can't see putting another bulb in, when this one has less than 50 hours on it.
What do you think
Oct 29, 2007 | Radio Shack Cinego D-1000 Multimedia...
Open Questions:
Issue with the HDMI Input Hello. I have a Mitsubishi HD1000 DLP Projector that has an issue with the HDMI port. It has been working like a charm and I was very happy with the device, but suddenly, one day I tried to watch a movie in the normal conditions in my salon and the HDMI port didn't received any signal (I have been using it in this setup almost more than 2 years). All the rest of the functions (menus, and others ports like VGA) worked ok. Yesterday I tested another HDMI High Grade wealthy cable without success. But the strangest thing was when I tried another computer and partially it worked with 2 different HDMI cables but green color is not displayed anyway, then the picture looks like magenta. I tried a color pattern and in fact, green is shown like black. If I put again the computer that I usually used for movies, it doesn't display anything except "No Signal". Also I have opened the device and tested continuity from one extreme of the HDMI Cable to the pins soldered to the mainboard of the projector and it looks like all the 19 pins have continuity -but maybe one of them has some losses-. Resuming: - With the computer I usually used, suddenly it stopped to receive any signal with 2 different cables - With another computer, both cables shows the same behavior: the image is displayed with the exception of green (of course, sending a RGB pixel) - Could be the cables, but is too estrange that both have the same issue Anybody could help me? I am a little desperated with this issue :-( Thank you very much :-)
Feb 28, 2017 | Mitsubishi HD1000U DLP Projector
See all Mitsubishi HD1000U DLP Projector Questions
Mitsubishi HD1000U DLP Projector Logo
175 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
