Question about Roper RGX4634KQ Gas Dryer
How to change capacitor in roper dryer RGX3514PQ0?
  • Saul Nov 28, 2012
    I just found out there is no capacitor. I had to replace the motor.
    Top Expert:
  • Roper Master
  • 9,472 Answers
What capacitor?
Posted on Nov 27, 2012
  • Roper Master
  • 8,220 Answers
Dryers don't have a capacitor they use a cent switch to get going. When you press start you energize the cent sitch in the motor. When it gets full blast weights mounted inside move the cent switch and release the power from the start wire to the run wire inside the motor. Why does it do it? 2 windings kick it into gear one drops out when she gets up to speed. Clever aint it?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 31, 2015
2 Suggested Answers
SOURCE:
onthejob5130
  • 640 Answers
SOURCE: dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Posted on Dec 28, 2008
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
My roper dryer won't turn on. i rewired the back to put a new cord on and now it wont start
Here is a tip that will help you with changing your dryer plug.Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2011 | Roper RES7648E Dryer
No Heat. Roper gas dryer model # RGX3514PQ0.
Hay Bud, you have an excellent excuse to buy a multimeter congratulations.. when you do, access the burner assembly and controller circuit board, on your disassembley you will likely find a wiring diagram, this will be very helpful in diagnosing your fault, let me know when you have the meter and the diagram and i will step you through the diagnostic proses.
Apr 28, 2010 | Dryers
Our Roper dryer stopped heating. We changed the
check the thermostat and overload (or thermal cutoff) located on the heaters housing...
Jan 15, 2010 | Dryers
How do I change a 4 prong to a three prong?
on the 3 prong hook up black and red then put green and white together
Nov 16, 2009 | Roper REX4634KQ Electric Dryer
Whirlpool/roper dryer won't start hear hum noise but doesn't start
open the back where you can see the mechanical parts (motor / belt / drum / capacitor)
1. unplug the unit, see if you can manually turn the motor head
If not , then the problem is the Bushing or bearing
If yes, then your starting capacitor ( Small aluminum type like a can with wires on top) change it.
check also the belt if it is correctly aligned.
Nov 08, 2009 | Whirlpool Dryers
Dryer tumbles, no heat
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Dryer used to overheat and shut down. was hard to restart,had to hold start button down. now will not start
Possibly bad capacitor on the motor. A bad motor can "mimic" a bad capacitor also. Without a capacitor tester, install a new capacitor, it's easy and cheaper than a new motor. Good luck!
Aug 18, 2008 | Roper Dryers
Roper RGX4634KQ Gas Dryer Logo
15,562 people viewed this question
Top Roper Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Roper Dryer Expert? Answer questions, earn points and help others
