Question about Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1880 does not feed paper when i give print command
My canon iP1880 does not feed paper when i give print command. It tries to print, make adequate sounds like printing but paper does not proceed to print.
SOURCE: canon ip4200 paper won't feed
It won't take the paper. It makes the noise and something moves in there. but it won't feed it through.
Posted on Feb 19, 2008
SOURCE: Canon pixma ip1800 --- load paper problem
pojkjjj
Posted on Apr 03, 2008
SOURCE: canon pixma mp460
I tried that and it's works : ))))
THANK YOU
Posted on May 09, 2008
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
pineworks
  • 4041 Answers
SOURCE: paper not feeding through for printing - Canon MP240
something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 14, 2010
When i turn on/off my printer,Paper Feed Roller automatically push the plain paper(A4)
hi . you should check the mechanism. there is a solenoid responsible for picking the paper up. clean the metal plate of the solenoid. it should be sticky and that cause that problem. good luck
Mar 15, 2016 | Canon PIXMA Office Equipment & Supplies
I have canon ip1880 when i give a print command it shows the message on my monitor ink cartridge cannot recognised - color
Solution: press and hold (10 second) reset button/resume (Button reset/resume, under the power button)
Sep 23, 2011 | Canon Office Equipment & Supplies
Will not print text from computer (paper feeds
PGBK cartridge was totally blocked. Deep cleaning did not resolve block. Replaced ink cartridge (large black).
Feb 07, 2010 | Canon PIXMA MP160 All-In-One Printer
I cannot figure out how to load the paper in my new canon mx300 printer. I put the stack of paper in the back of the printer, but none of the sheets will feed through. Any suggestions?
Hi,I assume you gave a print command from PC but printer did not print?
Did you try to make a "copy" of something ? as photocopier function. thru the command keys on the printer..
Please give me more detail then I can give more solutions..Regards
Jan 26, 2010 | Canon MX300 Office All-In-One Printer
Print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
Sep 08, 2009 | Canon LASER SHOT LBP-3000 Printer
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
Jul 21, 2009 | Office Equipment & Supplies
Canon i475D Printer
Try cleaning the rollers where the paper feeds in, a cotton bud with metho works on my printers
Apr 15, 2008 | Canon i475 InkJet Printer
Printing business cards on Canon PIXMA iP1880
go into your printers folder from the start menu on your computer. right click on your printer folder and select printer preferences. Under the page setup tab you can select the paper size and type of printing you want. if you select the card type you should be able to print business cards
Mar 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
PRINTING PROBLEM WITH CANON IP1880
Shut the printer off. Than unplug it's power. Than unplug the USB/data cable. Wait about ten minutes. Allowing printer to reset it's self. Go to pg. 37 of your manual & follow instrctions for cleaning. Connect the power cable, the usb/data cable & turn on the printer. Test printer for error paper jam (light/display message). Canon's web site for drivers, updates, software & guides. PIXMA IP1880 is the iP1800 series.
When web sites loades you must choose your operating system from the drop-down menue.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=14991
Problem not corrected? Uninstall printer software. Re-start PC. Re-install software. Re-start PC & re-test.
Hopefully you will not need to uninstall & reinstall.
Feb 11, 2008 | Office Equipment & Supplies
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
23 people viewed this question
old marine
old marine
