Question about Toshiba 43H70 43" Rear Projection Television
Blue rainbow on the bottom of screen
The bottom of my screen has a blue line giong upward from corner to corner causing a double vision i tried ajusting the convergance but could not adjust.could you please help me with a solution or give me a ideal on what i will need to do to fix this problem. Thanks Dennis
  • Dennis Parrott Jun 08, 2007
    Thank you for responding i appreciate it i was wondering if you have a idea on the cost of this repair i paid 350.00 for this tv used. would it be worth repairing.Thanks again Dennis
    President:
  • 3,130 Answers
You will need to replace or have the convergence IC's replaced. There are two IC's on the printed circuit boards that need swapping out. you should call in a pro to assist you in the=is repair if you have no solid state repair experience. good Luck
Posted on Jun 05, 2007
Rainbow showing up at bottom and top of screen creating double and triple vision
IM GUESSING ITS A LAPTOP SCREEN OR COMPUTER IT COULD BE SOME WATER TRAPPED INSIDE OF THE SCREEN LIKE CONDENSATION WHICH COULD MAKE A PRISM OF LIGHT LIKE WHEN YOU SEE A RAINBOW BECAUSE ITS SUNNY AND RAINING
Oct 08, 2009 | Philips TV Tuner Video Capture PCI Card -...
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
Blue line trouble
Hi Kracka,
Are you able to post a picture of the problem?
It sounds from your description that it might be a 'convergence' problem which is when the red, green and blue parts of the image aren't alligned properly.
Check in your menu to see if there is a convergence setting.
Hope this helps
Andy
Jun 26, 2008 | Panasonic PT-51G41 51 in. Rear Projection...
Convergance problems?
did you adjust the convergence
on the menu?
Jan 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
BLUE DOUBLE VISION
It sounds like you may have a loose solder connection either in the convergence circuit or the pincushion correction circuit. If you can't visually locate it, you may need a service manual and test equipment to track it down. I doubt that changing parts will be the cure if it is an intermittent problem.
Dec 16, 2006 | Samsung HCN473W 47" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
