Question about Acer Aspire AX3400-U2022 PT.SE202.007 Desktop PC and Microsoft Office Home and Student 2010 Product ... (PTSE202007BUNDLE)
I turn on my Aspire ax3400 and the fan works but the screen says no signal
There is no blue light on the computer switch. I shut the computer down a couple of days ago when before we went on a trip.
Same model, same problem. I found a thread (here?) that said the power button itself is the problem and sure enough, I took apart the front assembly and manipulated the pushbutton toggle until the computer powered up w/ the blue light. The power button assembly is really jammed in there - maybe that's why it's failing.
Posted on Jan 26, 2013
  • Neill White Jan 28, 2013
    Just wanted to add one thing - if you power on the machine and get the fan but no blue light, power down by holding the button down then immediately press the button again to power it back up to the blue light. For some reason, that seems to work.
    Problem Solver:
  • 7 Answers
First make sure all cables are plugged in correctly. Next step would be to make sure the monitor is working. Try hooking it up to another computer tower if you can. If the problem persists try re-seating you're graphics card.
Posted on Nov 26, 2012
SOURCE: Acer Aspire L100 will not power up
It's most likely not the power supply. I have a customer with the same problem. I used a power meter to see if the power supply worked and it checked out perfect. (You should still test it though, just in case.)
The only thing I can figure is a bad motherboard. Unfortunately, there's no visual signs of overheating, arc burns, or the like on this one to make it obvious... just one capacitor (the small one nearest to the power port) that has a slight bulge.
These things don't seem to be build to last, from what I've been reading.
Options:
-Break it down, sell the parts that are likely to still be good (wireless minipci card, memory, processor, heck - maybe even the front ports if you get longer cables/extensions), and maybe make around $200 that can be invested in a reliable machine.
-Or drop money into replacement parts. (but after what dj said about a second mobo going bad, I don't think it's worth investing more in this)
Posted on Jan 10, 2009
ODCaloney
  • 260 Answers
SOURCE: Computer start up problem
Capture the message that is displayed on the BSOD. There will be a bunch of numbers that will tell you what is wrong. I would open the side and re-seat the RAM and do a general cleaning of the fans.
Posted on Mar 16, 2009
  • 199 Answers
SOURCE: acer aspire ase380 power switch problem
do you get the self test screen on the monitor. is so it is not communicating with comp. bad video port most likely
Posted on Jun 27, 2009
  • 166 Answers
SOURCE: we have an acer aspire M1640. won't respond
unplug everything for a few hours and let it drain. then go into bios and turn off all power save settings.
Posted on Aug 23, 2009
SOURCE: Acer Aspire X1700 Desktop Wont Start up Shut down
That's Blue Screen of Death. Start up ur pc in safemode by pressing F8 key while booting and uninstall any recent hardware or software installations. Or try System Restore to an earlier date. If u failed to boot up ur pc even in Safemode, make a clean and fresh OS installation.
Posted on Jul 30, 2010
What could be wrong with my 2006 Chevrolet HHR?
The first place to start would be with the new ignition switch.What you are saying sounds like a defective switch.
Dec 09, 2014 | 2006 Chevrolet HHR
My furnace stopped working. It'd start up shut down start up shut down all in the matter of seconds. Then would fire up and work. it did this maybe once every couple days then it stopped all together. ...
Replace pressure switch. If you blow any air into the pressure switch it has been damaged,check air ports for debris by looking never ,never blow on air switch they work on a very small pressure or vaccum,where your breath is to much pressure and also loaded with unwanted humidity.
boilerman56
Mar 04, 2011 | Goodman GMS90703BXA Heater
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
I have a 1998 Moto Guzzi EV 1100. I was on a long
These are infamous for side stand switches that allow the bike to shut off and more importantly not start when side stand is down. Even worse is that it can activate even with side stand up. So either pull it off and short it out or clean up the connections.
Aug 03, 2009 | 2003 Moto Guzzi California EV
Hp mini 1000 - no startup display
you got error this windows/OS system so u need to re-install the OS/Windows..good luck and have nice day
Jun 18, 2009 | HP Mini 1000 Netbook
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Cintiq 12WX screen not working :(
may be the power chord is damged go to a nearby shop and tell tham to give you a new power chord of monitor and then try it should work fine
thank for visiting fixya
have a nice day
Feb 19, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
My hp ze4300 will not turn on
Has there been a power surge meanwhile? If so, try unplugging the power cord, press the power button, reconnect power and try booting. Sometimes works.
Oct 19, 2008 | HP Pavilion ze4300 Notebook
Red Screen
try tapping lightly on the tub that matches your color problem.
do you see it come and go? if so then you have bad tubes.
you can try to rejuvenate them but is not recomended.
Jul 06, 2007 | Akai PT5598HD 55" Rear Projection...
Acer Aspire AX3400-U2022 PT.SE202.007 Desktop PC and Microsoft Office Home and Student 2010 Product ... (PTSE202007BUNDLE) Logo
394 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
