Question about Lemax Village Collection Carnival Village The Starburst With 9v Adaptor
My lemax Starburst is not turning on the front color leds on the wheel.
When turn on, the wheel start to run. Lights on the back turns on, but the front leds on the wheel are not turning on. By pushing the front of the wheel, it turns on, but as soon it is released, lights turn off.
I purchased led turn signal lights for my yzf600 and they work but dont blink and also they turn off my front turn lights. i took out the indicator signal bulb and it still did not work
you need to get a relay to suit L.E.D lights, and as far as I know, you will have to run L.E.D lights(indicators) on the front aswell as the rear.
Dec 06, 2012 | 1997 Yamaha YZF 600 R thunder cat
Replaced lamp on samsung dlp - will not turn on - color wheel is intact but will not move - it sounds like TV is trying to start up but after three tries all three LEDs turn on - is this possibly a bad...
No,the tv colors wheel it is also dead or lose connections somewhere,because there no movement at all and all the LEDS indication lights are flashing and not giving power voltage to the tv colors wheel part at all.
Jun 22, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
May 01, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a samsung hlp5063wx. I just replaced the color wheel. It worked fine for two days. Then no picture or sound. After I turn the tv on the lamp LED on the front flashes. Then it goes thru its cycles....
If the color wheel doesn't spin, the lamp will not fire. The lamp has a gap in it, it will read open. Pull the rear cover off trip the door switch and look close and listen. Double check that the color wheel does not spin up (turn on, then wait 5 secounds or so.. pull the power cord and listen for it to stop.. best method). Also, watch the lamp driver.. there is a condensor coil on there that will lite up when it is sending the ignition pulse to the lamp... do you see it? If so, it's the lamp.
Apr 28, 2010 | Samsung HCM4215W 42" Rear Projection...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I have the 3 blinking LED lights which form the
Color Wheel, CK all Fans make sure they are running
defective Lamp Fan will shut set down, Pull Lamp out Look inside where Lamp plugs in see if Color Wheel is Turning. Encompass Parts Distrubtion has Parts for this TV 1-800-638-3328 or Just Go to their website.
Mar 23, 2010 | Samsung 56" Slim-Depth LED DLP HDTV
Cooling fan is loud . I'm going to replace the lamp in the unit because all 3 lamps are blinking on the front panel. Unit shuts down but I'm wondering if there is a seperate cooling fan in the back of the...
That's probably the Color Wheel you are hearing. When you turn the set on the color wheel has to run, one of the several things that has to happen for the set to come on. The color wheel sends a signal back to the control circuit to tell it it's running. If these sets fail to light the lamp they will shut off and try again, that's why you hear the color wheel start then wind down then start again. The set should try three times before it decides it's not going to be able to turn on.
One way you can tell the difference in the fan sound and color wheel sound is if you can get the set on, let it run for a little while so it gets warm, then when you turn it off the color wheel will start winding down but the fans will continue to run for a minute or two.
Mar 25, 2009 | Samsung HLN617W 61" Rear Projection HDTV
HLN5065W picture turns black and white and shuts down
Sounds like your color wheel may be at fault. Do you ever hear any unusual noises coming from the rear of the TV? Color Wheels usually make a humming sound as they go bad. This is because the tiny bearings in the color wheel motor have begun to misshape from use and heat. This is a known issue in this TV! Expect to spend $300-500 to have this serviced by a service company. If you have the right stuff, you can do it yourself. If you search the web, you'll find a color wheel for this TV for under $100, but installation can be tricky.
michtech
Feb 16, 2009 | Samsung HLN5065W 50" Rear Projection...
Lemax Village Collection Carnival Village The Starburst With 9v Adaptor Logo
57 people viewed this question
Top Lemax Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Lemax Toy Expert? Answer questions, earn points and help others
