Question about Epson EB-X02 Video Projector
Connecting Sony Bravia TV to Epson EB-X02 projector
Connected yellow RCA cable on Sony Bravia TV to yellow slot on Epson EB-X02 projector... but still "No signal"
chansimon
  • 42 Answers
SOURCE: 3000z TV Connection Cable
The cable is just a common design for most of the other mades. You may even DIY one very easily.
Posted on Feb 09, 2008
gjahn
  • 110 Answers
SOURCE: how to hook up cable from the wall to epson ex30 projector
The Epson is a monitor only. It has no tuner, so no cable connections. If you have a cable box or VCR, or DVD with RCA Style Connectors (yellow, red and white) connect your cable coax to the box or VCR and then the video and audio outputs on the box or VCR to the projector and select the video mode.
Posted on May 29, 2009
  • 8909 Answers
SOURCE: I have a DELL XPS Problem
Try setting the resolution to a value compatible with the projector and try again.
Posted on Jan 06, 2011
tulsatigger
SOURCE: My Windows XP is connected
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Posted on Jun 12, 2011
SOURCE: i have epson eb-s9 projector and when i connect with my pc half of the view its yellow... the projector is new i dont think is a lamp prob... help me plz
Try uninstalling the software for the projector and try installing again. During uninstallation, select to clear all the data created by the software. If it doesn't work, go to google.com and search for support.
Posted on Jun 27, 2012
Connecting wii to Sony bravia tv
If you have an old V.C.R that has Red, White and Yellow sockets for AV and it still works then plug it into the RF socket tune the V.C.R to your TV and connect your Wii to the Red,White and Yellow R.C.A connections and you should be playing in no time. I have done this myself on a new Samsung TV it will work. If you have no V.C.R and you have HDMI sockets in your TV you can buy an adapter to convert the existing AV port on the Wii to HDMI then simply connect a HDMI cable (if you have 1 if not they are cheap enough off eBay starting at $6.00+AUD or around $20.00AUD Retail) to the Wii and then the TV ensuring that both the TV and the Wii are powered down prior to connecting any cables at the back. The HDMI Adapter for Wii is available on eBay from $5.00 AUD to $24.95AUD depending on the country you purchase it from. If all else fails a second TV with Red, White and Yellow RCA plugs will work but also the most expensive of the fixes. All fixes suggested will work. Good Luck I hope this helps.
Jan 12, 2013 | Nintendo Wii Video Game Consoles & Games
I have a epson eb-s9 it has started to show a yellow tinge border around top and left of image
the lcd panel is break ,or the polarizer is break ,
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Oct 09, 2012 | Epson ELPLP58 - V13H010L58 Projector...
I have epson eb-s9 projector and when i connect with my pc half of the view its yellow... the projector is new i dont think is a lamp prob... help me plz
Jun 25, 2012 | Epson POWERLITE S9 PROJECTOR
How to connect camera to sony bravia tv.
Connect your camera in RCA cable (the one with a red, white, yellow connector for audio/video connection). Then connect it to your Bravia TV.. Set your Bravia TV in video mode, (the mode when you're playing DVD player in your TV)..
Note: Your video mode depends on where you connect your RCA cable. There are up to 3 video mode, Video-1,Video-2,Video-3
Then turn on your camera..
May 22, 2011 | Cameras
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
In my dorm room I have a N64, which works when I hooked it up. However it wont play in color it's only in black and white which is extremely annoying. I have a Sony Bravia. How do I fix this without...
You have more than likely connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables, COMPOSITE only uses one (the yellow plug). If you connect only one video cable to any of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check the connections on the rear of the TV and make sure you have not connected to a socket marked "COMPONENT", "Pr" "Pb" or "Y". If you are certain the cable is correctly connected, please try another cable.
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV. I will then be able to assist you further.
Regards,
BElectric
Jan 10, 2011 | Televison & Video
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How to hook up cable from the wall to epson ex30 projector
May 28, 2009 | Epson Televison & Video
How do i connect cable tv to my dell 2200mp projector
You can connect it directly with a composite cable. There would be a RCA(yellow) video output on the back of your cable TV. This is then connected to Video input(yellow) f you projector.
If your cable TV has Component output (threr RCA cable Green, Red, Blue), then these thre RCA could be connected to the similar one available on your Projector.
You could connect your sound als o thru the RCA out of Cable TV and input of Projector. But if you have a good AV Receiver or a sound system then it best suited for it, since the projector speaker is mono and only 2Watt output.
Let me know if there are any specific inputs required
The Dell 2200 mp projector has the following compatibility
:HDTV: 1080i, 720p
EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes
Mar 03, 2009 | Dell 2200MP Multimedia Projector
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Epson EB-X02 Video Projector Logo
279 people viewed this question
Top Epson Televison & Video Experts
janman
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
