Question about Lexmark X656de AllInOne Laser Printer
I need to reset my lexmark x656de to factory defaults
5 Suggested Answers
SOURCE: Right Cartridge Incorrect
I prefer to buy a new color cartridge cause if you have right cartidge incorrect it means that your printer cant read the catridge. GOOD LUCK!
Posted on Jan 03, 2008
  • 77 Answers
SOURCE: Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Posted on Sep 08, 2010
  • 6 Answers
SOURCE: how to reset lexmark e260dn on factory defaults
Power off the printer
Remove the network cable
Open the front of the printer
Hold the Continue button
Turn the printer on
After the lights cycle a few times, let go of the Continue button
Close the front of the printer when the yellow light is on, telling you that there is an error (because the front cover is open)
There will be 4 lights that will be on, press the X (cancel) button and it will turn into one light. Hold the continue button down, it will print the Printer Settings Configuration page which will instruct you further.
Posted on Dec 08, 2010
Printtech
  • 1087 Answers
SOURCE: lexmark x656de erro 929.03 service toner sensor
Please try to use a spare toner, if you have tried using the spare toner and you still get the same error, this maybe a sensor issue (40X4370 Sensor).
If you need further assistance, please contact Lexmark Technical Support.
Posted on Oct 12, 2011
How to reset fuser kit on X656de
  • 01: Lift the paper bail, and then remove the fuser wiper cover
  • 02: Remove the top rear door
  • 03: Open the fuser cover
  • 04: Remove the fuser
  • 05: Remove the new fuser from the packaging
  • 06: Insert the fuser
  • 07: Close the fuser cover
  • 08: Attach the top rear door
  • 09: Lift the paper bail, and then insert the fuser wiper cover
Or watch this video
Lexmark Product Videos
click on Service Maintenance
then click on Replacing the fuser
Manual X651de X652de X654de X656de X656dte X658d X658de X658dme X658dfe...
May 11, 2014 | Lexmark X656de AllInOne Laser Printer
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
Factory reset lexmark x203n
I do not think resetting to factory defaults will solve this problem, anyhow this is how to reset the X203 to factory defaullts. Turn it off, Kepp press?d keys "check mark" and "right arrow". Turn printer on, wait until some dots show in the panel and release the buttons. Enter CONFIG MENU, browse right/left until you reach Factory Defaults, press Select / Check mark. Done.
Sep 24, 2012 | Lexmark black toner x203n/x204 return...
Lexmark x656de erro 929.03 service toner sensor
Oct 11, 2011 | Lexmark X656de AllInOne Laser Printer
I need the key combination to do a full reset on a Lexmark x6675 - can anyone help? Thanks in advance for any assistance forthcoming - Jeff
From the printer control panel, press Setup button > Defaults, press OK > Set Defaults, press OK > Use Factory, press OK. You will then be asked to select/enter your preferred printer settings just like the first you set it.
Source: How to Reset the X5600 and X6600 Series Printers to Factory Defaults
Jul 26, 2011 | Lexmark X6675 All-In-One InkJet Printer
My lexmark printer x4875 only copies part of the page
Try to reset your printer to factory default settings. Go to Maintenance -> hit check -> select Reset Defaults -> select first option only to reset factory defaults. Try to make a copy again.
Apr 11, 2011 | Lexmark X4875 InkJet Printer
How to I factory rest lexmark t650n printer
You can reset the Lexmark T650n to factory defaults in two ways:
A. Press Menu > go to Settings > General Settings > choose Factory Defaults
B. Go to Configuration mode by pressing and holding down Select button (check mark) and right arrow button while powering on the printer. It should display config mode. Choose Factory Defaults. Then power cycle the printer.
Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 27, 2010 | Lexmark T650DTN Laser - Monochrome Laser -...
4. Press "Select."
7. Press "Select."
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Administrator Password Reset to factory default
Hey
have you tried to reset the whole printer to factory defaults
**411 -> 4 -> 1 then the green go button
Regards
Daniel Knudsen
Jan 12, 2008 | Lexmark X4500 MFP Flatbed Scanner
Lexmark X656de AllInOne Laser Printer Logo
2,555 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
