Question about Marshall Mg50dfx 50-Watt Combo Guitar Amplifier
Crackling sound at quater volume, cuts out when turned up more
Sounds like a blown speaker on low notes but speaker isnt blown. cuts out completely but comes on when u smack the top. removed board, can reproduce problem by wiggleing the main harness to what im guessing is a transistor? ( the black box with all the wires going to it) checked all connections and they seem ok. could it be the black box itself?
I know what wrong i had the same problem see this black thing in the middle breaks from too much vibration crackling sound at quater volume, cuts out when tu - 55d39c2.jpg
Posted on Jul 09, 2009
Hi Sounds like you have dry solder joints on your pc. Carefully inspect the board and determine how to remove it (Slowly! do not force it out). Turn the board over and with a magnifying glass inspect the solder points if they look Rough or Dry Gently touch them up with a Soldering Iron. If there appears to be a Hole in the solder be careful and apply a bit of solder with a Soldering Iron. Remember to use low heat on your Iron so as to not lift any traces on the pc board and not to leave the Iron on the joint More than Necessary. Good luck, Dereeldeel
Posted on Jan 18, 2009
Fishman Loudbox amplifier rattle sound on bass notes
Either the speakers have loosened from the faceplate, or one or more have blown. Open the amp and tighten them down. If that doesn't fix it, remove them a take them to the nearest speaker repair shop for a checkup. If blown either have them re-coned or replace them.
Oct 06, 2016 | Fishman Loudbox 100 Acoustic Guitar...
Static at louder volumes
All you need to confirm is to remove the connection to the guitar, remove the jack and cord to the guitar and now check if the noise is prevalent at higher volume, when the volume control is turned up. If so the fault is with the cord , the jack or the gutiar pick up insulation or internal connection or shielding.
Cross check with a seperate cord or another amplifier to confirm the case.
If the noise is from within the amplifier then it is possible there is fault in the preamplifier, fault with shielding of the inputs or the preamp, broken groung connection.
Compliments of the Season.
Dec 24, 2011 | Roland Ac60 Acoustic Chorus Guitar...
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
Crackling sound in speaker
These speakers have a history of being blown if played too loud. Apparently the higher quality CX version are reliable. If the lows are what is crackling, the voice coils are probably cooked causing it to drag the pole pieces.
Apr 28, 2011 | M-Audio Studiophile BX5A Deluxe
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
Marshall MG50 DFX, the volume knob OD channel crackles
Either the control is damaged (happens if they get hit) or it is possible the circuit board it is mounted on has broken solder OR worse, a crack near the control. The unit will require servicing. Parts are readily available.
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
When I turn the volume past 12 o clock on my PX320 when playing hard the sound clips out. Drops out completely. Any solution to this?
The numerical settingor position of the volume has very little meaning.
If you are clipping, you are overdriving the unit and the unit protects itself.
OFTEN WITH guitars that have preamplifiers built in, one can overdrive the bass amp very easily, even at low settings of the volume control..
Do not continue to overdrive the unit as it is hard on the speakers... without the clipper, you would likely have blown the speaker(s).
IF YOU NEED it louder, then buy a larger amp and speaker setup.
Jan 07, 2010 | Casio Music
Fender m80 ...hey before im sorry bout my poor english.
output caps, replace them.
also the speaker could be getting tired.
Dec 07, 2009 | Fender Fm25dsp 1x10' Guitar Combo...
My Fender Rumble 25 makes a terrible crackling sound when the volume is turned up over the 4 or 5 mark. I don't think the speaker is blown as the same sound comes via the headphone socket.
Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Rumble_Bass_Schematic_-B21.pdf Check the tubes to see if one is loose in its socket. Do not attempt to repair this yourself unless you have amplifier repair experience as it is easy to get a bad or life threatening shock without the correct test gear and troubleshooting procedures.I hope this helps.
Nov 26, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
Mar 01, 2009 | Roland Juno-D
Marshall Mg50dfx 50-Watt Combo Guitar Amplifier Logo
323 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
