Question about RCA Universal Remote Control
Cann t program my remote control
Ilost my manual and Idon't have the code to program it back also I don't know the steps to follow to proram it to tv (sony)
  • 4 Answers
Hold down setup button until tv light comes on then hit channel up button over and over untill tv channel changes then hit enter
Posted on Jan 10, 2009
Need to program remote back to RCA HDTV Model# D52W19
download the manual for steps by steps from www. fitness.manualsonline.com or www. retrevo.com and fix it
God bless you
Jul 03, 2013 | RCA RCR311TFM1 Remote Control 261669
Tip
DISH Solo DVR VIP612 Program TV VCR Remote Code
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | DISH Network ViP 612
Tip
DirectTV RC65 Code Search
TIVO DirectTV RC65 Remote Control Programming by Code Search
Here are the steps to program your TIVO DirectTV RC65 remote control using Code Search:
  1. Turn on the TV or component.
  2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by one of the following four digits: 0 for Sat box, 1 for TV, 2 for VCR/DVD/PVR, 3 for Stereo.
  5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
  6. Point the remote at the TV or component and press CHAN UP. Repeatedly press CHAN UP until the TV or component turns off or performs the action you selected in step 5.
  7. Use the CHAN DOWN key to step back a code.
  8. When the TV or component turns off turns off or performs the action you selected in step 5, stop pressing the CHAN UP key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available.
If you know the 5-digit code you want to use, follow these steps.
To download and electronic copy of the DirectTV RC 65 manual, click here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
I have chunghop RM-88E,idon't know the tv code of
Have you all of these sets? Wow. Try to to download the user manual to chunghop. It is very difficult to type codes for all of these brands here.
Mar 11, 2013 | Televison & Video
How do i programe my dish remote to my Sanyo tv and to my dish reciever
The Dish TV remote control allows you to program the TV, VCR and DVD codes so that all you need is one remote. Most TVs can be programmed into the remote using specific codes in the Dish TV remote manual. But if you don't have a manual or list of codes, you can program the remote manually.
Instructions 1. Using Programming Codes
Find the TV code for your TV in the list from the Platinum Remote Control User's Guide (See References). For example, if you have a Kenwood TV, the three possible codes to try are 506, 573 and 712.
Press the "TV" button on the remote. Hold down the button until the "Sat," "VCR" and "Aux" buttons light up. Release the "TV" button and it will be flashing.
Enter the first code using the keypad. If you want the remote to control all functions on the TV, enter the code and press the # key. The "TV" button will flash three times.
Press the power button to turn off the TV and turn it back on again. If the code was correct, the TV will turn off and on. If the TV doesn't power down or back on, follow Step 6.
Try the next code from the list. Follow Steps 2 through 4 using each code until one turns off the TV.
2. Programming Without Codes
Press and release the "Power" button on the remote.
Press the arrow up key and stop. If the TV doesn't turn off, press the arrow up key again. Continue pressing the arrow up key until the TV turns off. Do not go fast when moving through the codes or you could miss the correct code. Press the arrow key and wait at least 20 seconds to see if the code works before pressing the arrow key again.
Press the # button on the remote control when the TV turns off ot lock the code.
For codes and more details, Visit this site for more details. The site name is (Electro-help). Just type in "electronicshelponline.blogspot" into the search box of your browser, and click search. You can see a site by this name. Pull up older posts there. Sometimes, ads related to each post might give you details about the availability of spare parts and price. It is a blogspot site, in English Language
Jun 27, 2012 | Sanyo Televison & Video
I bought a new TV and need to program my Dish network remote control
Hey scrappy32847,
Congrats on the new TV! I can definitely assist you with this and get it taken care of. As I don't know what TV you have I don't have any codes off hand available.
You can check out this link: http://www.dishnetwork.com/SupportSection/remote-setup to get the codes to program your remote. I have also listed the steps below to program that remote to your new TV.
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
If you need any additional assistance you can reach me here or at thomas.faust@dishnetwork.com
Tommy Faust
DISH Network
Jun 24, 2011 | DISH Network IR Remote Control
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
I need to program my philips universal SRU3004WM?17 remote but ilost my manual
1) Press and hold Setup
2) Press once the device button (TV,VCR,SAT) once
3) Enter the code for the correct device that you want
For codes, check here.
Apr 10, 2010 | Philips SRU3003 Remote Control
How to program an RCA RCR450C. I also need codes for a tv Hitachi 27SC48 adn a Magnavox CCR136AT02
The REAL solution. The link below is the manual to the RCR450. It shows a pic of the remote which is exactly like the RCR450C. This will teach you how to program the remote and it gives you the codes for the different types of equipment for the universal remote. When the web page comes up, click on "click here" that is in red. Save this manual in your Adobe files for future reference.
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
Jan 07, 2009 | RCA RCR450 Remote Control
Televison & Video Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
