Question about Estate TAWS800JQ Top Load Washer
I need to install a coupling into my washer. hows that done?
    President:
  • Estate Master
  • 2,651 Answers
Easy enough repair, you can get a video instruction fom you tube, search,, motor coupling whirlpool washer. take you all of 20 min!!!!!
Posted on Jan 10, 2009
Install motor coupling for washer
You take the top control panel off. There are two screws behind it, or there are two clips under the control panel you'll have to use a putty knife for. Or if its a kenmore, the sides of the control panel may come off exposing screws. The unit will then need the lid switch and two brass clips removed located under the control panel you've figured out how to remove. Lift the lid and pull the shell back. On the bottom now theres your motor. Remove the two clips holding on the drain pump, then the two clips holding on the motor may be connected with two 1/4 in bolts. Then you pull the motor off after disconnecting the wire harness. It's connected to the motor and the transmission. Make sure that coupling is on tight.
Mar 19, 2013 | Whirlpool Washer Motor Coupling 285753A
During the spin cycle the water drains but it doesn't spin. Clothes were stuck to the sides of the washer but completely soaked.
Greetings,
if your washer will fill up and make the sound like its working, but not agitate, and it drains the water, but will not spin..The most likely culprit is a broken drive coupling. I would fill it up on a small load and see if it does what I said.....if so, lean the washer over so you can work under the front of it. there will be two clips that hold the pump on..remove those, but remember how they came off...pull the pump off the motor and set to the left side. .. next, there are usually two screws in the two clips that hold the motor on. Remove those screws and remove those two clips making sure you see how to re-install them.. while removing the last motor clip, be careful as the motor will fall out....on the one side of motor will be a coupling...this may have a broken ear or be split..its possible, it will be ok...now, look into area where the motor fits and you will see a black round piece of rubber with holes in it..this sits over another coupling on the transmission shaft...this is either broken, or the motor coupling is or a combo of both. if broken, remove and order yourself a drive coupling..re-install and put everything back in reverse order..when installing these you will have to drive them on with something that fits between the center of the new coupling, so you do not break the ears off..I use a deepdish socket....it works well with installing the new coupling on the transmission..........if by any chance the coupling does not look broken, its possible to be rounded and slipping on the shaft..if you determine its not...then the basket drive or transmission is gone out...this time you will need a service person to repair......Bruce Denton ps..if you find out i was correct , please let me know here..thanks
Dec 13, 2010 | Whirlpool WTW5321S Top Load Washer
I have a two speed automatic whirlpool washing machine
It sounds like your motor coupling has broken. Normally the older the machine gets,the more wear and tear on the coupling. Order the coupling as per the model and gain access to the main motor. remove both clips holding motor then pull off broken pieces then install new kit.(easy to see how). Reinstall motor and retry. Done.
May 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My husband replaced the coupling on our kenmore
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
I'd verify that the Motor Coupler is installed correctly first.
I'd also verify that the Lid Switch was re-connected after replacing the coupler. (A common oops that I've done myself)
If it was, I'd test the Lid Switch by jumping the two outermost contacts with a short piece of insulated wire.
See the Whirlpool Service manual for their top load, direct drive washers for how to bypass the switch.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Apr 27, 2010 | Kenmore Washing Machines
How do i replace motor coupling on whirlpool washer
two screws on the control panel on the corners front or back
with those out roll the cove up and back
disconnect the lid switch clip on back wall
pop the two body clips with a screwdriver
pull off the cabinetpull the clips off the pump
pull the pump out of the way no need to disconnect
sam two clips on the motor
pull those off asnd drop the motor
the coupling goes betwen the motor and transmission
work backwards
youre done
Oct 03, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Not draining or spinning
There is a coupling in between the motor and transmision cost about 10 bucks if that much. Sounds like you need a new one. Flip washer on it side and look at the motor where it connects to the transmission you will see a coupling.
Nov 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore elite washmachine
kinked hose adjust hose so unkinked
or water pump clogged sometimes socks get past drum into water pump
water pump sends the water out
these are the main reasons the washers wont drain
couple things needed for pump removal
bucket and a couple small cups
pull water out
once low disconnect power turn the water off disconnect
you will need someone strong and a dolly
take out side the little water left in will make washer heavy
once outside tip back lay down on side angled up a little pull pump out pull debry out with needle nose pliars 2 people needed here then put pump back in done
this is self service solution
this can be done without service person
or you could call maytag
Jul 06, 2008 | Kenmore 22422 Top Load Washer
Hjh
pull water out
Kenmore Elite Washer : HELP
Will need the model and serial number of the unit before any troublshooting can be done. Could you supply this information?
Nov 07, 2007 | Kenmore 24032\24036 Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
35 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
