Question about LG LSC121PMA Split System Air Conditioner
LG split system air conditionsr
I have an LG split system air conditioner. It has worked fine until about a month ago. Suddenly one unit wouldnt respond to the remote. I have changed the batteries etc. Occasionally it just works and then wont respond the next time. I have force started it etc and now the green light is in a loop flashing three times at intervals of about 1o seconds. Why wont the thing respond...it's driving me mad
  • Anonymous Mar 13, 2014
    Our lg inverter cooling only aircon is having a major tantrum. Turned itself on and wouldnt turn off via remote until we switch off the house power and now wont turn back on via the remote and keeps beeping like it's trying to re-set itself.It's possessed !! Help - Cheers - Michele
  • Anonymous Mar 23, 2014
    not responding, flashing orange
  • 1,420 Answers
3 flases indicates a communication error. Have a technician check wiring and connections.
Posted on Aug 30, 2007
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
I have a split unit that was installed about 8 months ago. It worked fien until the hot summer came. Suddenly it began to drip on the wooden floor beneath it. I checked the drain outside and it seemed to...
If your unit is only 8 months old, then it should still be under warranty! Suggest you check the drain line to make sure that nothing has decided to make it home.
I would check the level of your unit to make sure that there is a slight grade to the rear of the unit, but I hesitate to tell you to shim it.
Jul 26, 2011 | Mitsubishi MS-A09WA Split System Air...
Have an S30 AHP ND-6 split system a/con. Runs fine until second stage kicks in then it drops out the breaker in the main fuse box. ANy ideas?
Sounds as if the rotor in the compressor is grounding out to case. I don't see this very often
but it does happen. It can be intermittent but gets progressively worse until the unit will not
function. It also will run the utility bill up significantly.
Feb 22, 2011 | LG LS242HE Split System Air Conditioner
LG Artcool Error Code C1. What does this mean? (Background info A/C unit works fine, cools as normal. Installed 2 years ago)
Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor.
Nov 08, 2010 | LG LA185HV Split System Air Conditioner
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
We have 2. LA125HV w/ 1 condensing 1. air handler
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
Dec 07, 2009 | LG LA125HV Split System Air Conditioner
Heating & Cooling Logo
868 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Steve F
John Tripp
John Tripp
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
