How to change the rechargeable battery in it - Televison & Video
UNDER THE BOTTOM THERE SHOULD BE A BATTERY PACK WHICH YOU CAN CHANGE
Posted on Nov 27, 2012
Can I use rechargeable batteries?
didnt specify device --rechargeable batteries are a power source like regular batteries but you can recharge them when they get low and not change them out and buy new --so unless their is a special warning on the product specifically stating no rechargeable batteries you can use them
Aug 30, 2016 | Audio Players & Recorders
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
How to replace battery of wireless laser mouse mi
On the Top on the Mouse u can see the Battery u need to Remove the old Battery's and Replace with New battery see that you use Rechargeable battery because ordinary battery life spam is very less and u need to change the batterys for every 1 month so if u use the rechargeable battery then u need not change battery for 1 month at least for 5 or 6 months the rechargeable battery work and u can keep and spare rechargeable battery when every needed and try to purchase a Sony Rechargeable batterys deepakkumaar.jpg
Dec 14, 2010 | MSI Computers & Internet
Display says to change batteries..have done and still says to change batteries
Strange as this solution might sound,m it works; clean the battery contacts in the camera, as well as the battery itself with alcohol. Even a small bit of oxidation, at the current level the camera requires, drops quite a few mvolts, enough for the camera to think your battery is running low.
Anand
Mar 05, 2010 | Canon PowerShot A710 IS Digital Camera
Logitech Mouse asking me to change bateries while they are new
The rechargable batteries can start wearing out after some recharges. Try recharging the batteries or get a new set of batteries.
Jan 21, 2009 | Logitech Cordless Desktop EX110
It keeps asking me to change the batteries
If you haven't already, buy rechargeable batteries. I used to have the same problem. If you are using regular batteries, there juice is used up very quickly. I use Energizer rechargeable batteries and they recharge in 15 minutes. Also you'll have to buy the charger as well. I hope this helps your problem.
May 18, 2008 | Canon PowerShot A510 Digital Camera
Rechargeable batterie won't work in my Camera.
Not sure what camera you have, but some cameras require a very steady power supply voltage. Also not sure how old your rechargeable batteries are either, but batteries (alkaline and rechargeable decay over time. With the rechargeable ones, the more you use it, the less it can charge to full capacity over time. For example, if your rechargeable battery is supposed to charge up to 1.5V, over a period of a year with constant recharges, you can test with a volt meter and see that it never really goes back up to 1.5V, but more like 1.48V, 1.45V or maybe even 1.4V.
Depending on the camera or other item you use rechargeable batteries on, it can adapt to low voltages with special circuitry inside (but only to a certain limit, when a battery is old, it is old).
You can try buying a new set of rechargeable batteries and use it few times and see if this fixes the issue. If not, your camera may be faulty and just draining the battery (not too likely, but it happens).
Check out this site for some useful info.
http://www.steves-digicams.com/nimh_batteries.html
Apr 30, 2008 | Canon PowerShot S5 IS Digital Camera
Battery life is to short!!!!!
Its the camera, I have the same one and it eats batteries like nothing. I suggest rechargables.
Feb 17, 2008 | Fuji FinePix A700 Digital Camera
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
Dec 23, 2007 | Samsung Digimax S630 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
