Question about Cell Phones
Lg840g will not pair with ford sync system - Cell Phones
The phone will not connect with my 2010 Ford Fushion but I just rented a 2013 ford C-max and the phone worked great. It appears a code update is probably the solution.
Posted on Feb 13, 2013
2 Suggested Answers
SOURCE: cannot pair my voyager with
Have you tried to turn off if it is on or turn on auto pair if it is off and see if it works.
I had Problems pairing with a 2010 Kia Sorento and had to turn off auto pair for it to work.
Posted on Sep 18, 2010
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
When I answer the phone via the sync system (blue tooth) either via the steering wheel or touching the screen, the caller hears the rigning that I hear inside the vehicle. It is ear piercing. Ford says...
Try pairing a different phone with the system and see if the problem still exists. This could be a phone issue. The Edge Sync system uses the phone for commands. It totally depends on the phone to process all requests.
If you tried a different phone with no results log into www.syncmyride.com and check to see if you have the latest software level for your Edge.
Apr 21, 2011 | 2010 Ford Edge
How do i sync my samsung galaxy s to my ford f150
If you have SYNC GEN 1, v 3.1, you can pair the phone without too much difficulty. You turn on the Bluetooth on the phone and make visible before you turn on your key. Scroll through the SYNC menu to the pairing function and the number should appear on your SYNC screen. Type the pairing number into your phone. It may take a couple of tries to get the phone to find your SYNC. It does eventually do it.
The music player on the phone plays through the speakers, but the steering wheel controls have problems if you want to advance to the next track on the MP3 player. Neither Ford nor Samsung seems to have an answer to how to make this function work--some kind of software oversight in the Bluetooth version on the Galaxy S phone.
Jan 06, 2011 | Car Audio & Video
Cannot pair my voyager with Ford Sync system even after software update. Neither Sync nor verizon has been able to solve the issue
Sep 17, 2010 | LG VOYAGER VX10000 Cellular Phone
U430 will not work with ford sync
I have the same problem. Trouble pairing but finally I got the SYNC to find my U430 and paired but the SYNC never connects with the phone.
Sep 17, 2010 | Samsung Cell Phones
How do I bluetooth pair my i9 phone with my Ford SYNC
On your Ford Sync board, press the phone button. It will start to search for already paired devices. If none is found, press the arrow buttons until you find 'Add Bluetooth Device'. Then, press OK. You'll see it will generante a PIN. Now, make your phone's bluetooth application look for new devices. After a while, the Ford Sync device will appear on the phone screen. Select it, and make the the bluetooth application proceed. When a PIN (or pairing code, or passkey) is requested, enter the PIN generated by the Ford Sync device.
Hope it works for you.
Regards, Carlos
May 20, 2010 | Cell Phones
SGH-u700 - Ford Sync - Bluetooth - downloading phonebook
contact your samsung mobile store and have them upgrade the sync for you to pair with the car.
May 30, 2009 | Samsung SGH-U700 Cellular Phone
I was having the same problem.. I had to get a new phone in order to download the phonebook. I got a samsung A827 andit took care of the problem. I had to go to the phone store and trial and error phones until I found one that worked. The list on Syncmyride.com contains many older phones that the stores don't carry anymore. Good Luck!
Apr 30, 2009 | Samsung SGH-U700 Cellular Phone
LG VU unpairs from Ford Edge with SYNC
lg vu 920 does not pair with my ford sync , other set in family do only the lg vu 920
Dec 13, 2008 | LG Vu CU920 Cellular Phone
Cell Phones Logo
287 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
