Question about Whirlpool Duet GHW9150P Front Load Washer
F24 comes on. Just won't work. I have tried turning off power.
Door opens. I press start & auto goes back to F24 help
  • Anonymous Jan 25, 2009
    same here
  • 8,197 Answers
The F24 error code indicates a problem with the water temperature sensor. The technical explanation for this code is provided in the first image below. The location of the temperature sensor is shown in the second image. The temperature sensor is Key 24. The third image provides the testing procedure for this component. To access the temperature sensor, unplug the washer and remove the back panel. Unplug the wire harness connection to the sensor and check the resistance with a volt/ohm meter. If the sensor is apparently bad, it will need to be replaced. You can order a new temperature sensor from the Sears PartsDirect website www.searspartsdirect.com . The part number is 8181705. If the thermistor tests good, you could have a water fill problem, a wire harness connection issue or a failed control board that would cause this error code. If you need more help, resubmit your question with additional details and the full model number of your washer.
  • F24 comes on. Just won't work. I have tried turnin - image53469img-th.jpgView Larger
  • image53474img-th.jpgimage53475img-th.jpgView Larger
  • Posted on Jan 10, 2009
    Power window won't go down but you can here the motor running in the door
    You can remove the door handles and power window switches and the screws in the door pad and push up on the pad and it will come out of the track and then you can see the motor and replace the part yourself. Hope this helps.
    May 05, 2017 | Chevrolet Camaro Cars & Trucks
    Power door locks won't work and the instrument pnnel lights won't turn on. I replaced blown fuse a 20mp one in position 14 I believe. worked ok till I tried to lock the doors, the fuse blew
    Hello. Try looking at the black earth that goes from the drivers door and into the A frame which is covered in a rubber sheath. The wire can break after opening and shutting the door over several years and as it's normally the thicker wire is more prone to break. Also check the other wires visually for any chaffing and tugging on each wire. If more electrical parts start failing, air con blowers etc it will be an earth. Hope this helps
    Nov 03, 2012 | 2002 Dodge Neon
    Samsung microwave displays press 1-4...
    The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
    Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
    Driver side power window and lock not working
    Check the electrical connections for you control switches...there should be at least two of them. Disconnect them and see if there are any recessed pins or dirt. Do this several times as there may be some oxidation on the connectors and doing this will help clean them off. The radio and door light works of the small limit switch on your door frame. Everything else works through the operators window/door lock control panel.
    Dec 04, 2017 | 2006 Chevrolet Equinox
    6 month old 139.53985dm garage door opener shuts off going down
    Unplug unit at power source and check and tighten all connections in the control box. And try this link.
    http://www.garagedooropeners.us/technical_information.html
    Mike
    Mar 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
    2005 buick lacrosse
    lock rod has probably come off from door lock, try to get inside panel off or have someone with slim jim try and reach the rod to unlock the door
    Nov 27, 2008 | 2005 Buick LaCrosse
    Whirlpool gold start button flashing dishwasher won't start
    press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
    Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    F24
    does the drum just move back and forwards or does it turn complete turn if it dont do complete turn it might be that the belt is slipping and needs replacing this is cheap and easy to do post back if you need more help but i had a machine with same prob but mine was different make and model but after replacing the belt it solved prob and is still working to this day sorry if this is not much help .........................................................
    Nov 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    506 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
