Question about Foxconn FlamingBlade LGA 1366 Intel X58 ATX Intel Motherboard (6943296903751)
Meaning of error 89 - Foxconn FlamingBlade LGA 1366 Intel X58 ATX Intel Motherboard (6943296903751)
  • Foxconn Master
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
Hope it helps.
Posted on Nov 28, 2012
ERROR SYNTAX
Error Syntax mean that the structure of the entry is incorrect. For example, x+-y (x plus minus y) is invalid; whereas, x+ (-y) (x plus negative y) is correct.
Apr 01, 2013 | Texas Instruments TI-89 Calculator
I keep on getting domain error when calculating inverse normal with aera: .025 mean: 1 and standard deviation: 0 on my TI 89
This is to be expected. A standard deviation of 0 means that all the data points are identical. Asking for the point below which .025 of the data lie is meaningless.
May 25, 2012 | Texas Instruments TI-89 Calculator
What is the meaning of the error message "invalid axes"
This is problem with graphing differential equation. Invalid Axes error occurs if Axes=TIME or if t(time) is set as a CUSTOM axis. This is important to noticed: if Fields=DIRFLD you cannot plot a time axis. See captured image
Feb 08, 2012 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
TI 89 error memory when solving simple functions
Simple is a relative complex. What do you mean by solving a function?. Usually you solve equation to find particular values of an unknown, and you draw function to see what it looks like over a range of values.
Take a simple function: y =x. If you draw it with a step of 10^(-6) you will run into memory problems.
I suggest you clear the memory of your calculator and, if you are running a program that misbehaves you should correct the programming errors.
Hope it helps.
Dec 14, 2009 | Texas Instruments TI-89 Calculator
Abs( and square roots
The missing error means that you did not close the parenthesis. When you use a square root or absolute value it always gives you the left parenthesis, (, but you need to close it with a right parenthesis, )
Sep 25, 2008 | Texas Instruments TI-89 Calculator
Domain error
It's the "Exact/Approx" setting under the [MODE] key. I used to have it on "Exact" and got the domain error issue, but then changed it to "Auto" and it works. IMO, this is a really weird quirk that TI should have ironed out before releasing the TI-89.
Apr 02, 2008 | Texas Instruments TI-89 Calculator
Dec to hex conversion
Not sure if TI-89 mode keys are the same, but here's the solution for that calculator:
1. Hit the mode key
2. Hit F3 to get tot Exact/Approx (might be different for 89T).
3. Set it to Exact.
4. Take a look at T-89 manual pages 327, 328, 329.
Nice of TI to NOT include that in the manual, huh?
Dec 13, 2007 | Texas Instruments TI-89 Calculator
Foxconn FlamingBlade LGA 1366 Intel X58 ATX Intel Motherboard (6943296903751) Logo
73 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
