Question about Coral Sea Spas Ariel Platinum DA333F8 Steam Shower Unit
Takes forever to fill tub
Is it normal for the tub to take about 15 mins to fill?
  • 51 Answers
Yes now days all the faucets are regulated to save water so they dont fill a large tub very fast. if you take off the diffuser (the screen wher the water comes out) depending on the brand you might find a plastic disc that restricts the flow. Take that out and see if that helps. Try just taking off the screen assembly and filling the tub first. It it does not fill faster with that off then you have another problem,and taking out the restrictor plate wont help.
Posted on Dec 18, 2012
How to water flush a 4hp. mercury
Get a water tank / tub fill it with clean water make sure the water intake hole is well below the surface and start the motor and run for 15 mins and keep the tub fill of water
Nov 01, 2016 | Mercury Cars & Trucks
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
Gas pump shuts off like its full many times while trying to refuel.
Usually a blockage in the filler tube or a vent problem.
You may have to take the filler tube off and inspect it. There should be a tube inside or outside the pipe to allow air pressure in the tank to equalize.
Jul 21, 2012 | 2002 Lincoln Continental
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
Fuel fill takes forever on 2003 Hyundai Accent
Sounds like the charcoal canister - replace it.
Apr 21, 2009 | 2003 Hyundai Accent
Kenmore 90 plus won't fill on regular orpermanent press cycle.
OK, Duh..... I guess there is about a 2 to 3 min. delay for the liquid soap dispenser to fill up and disperse the soap into the washer tub. After that short cycle is complete the fill cycle engages and fills at normal speed.
Mar 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kitchen aide ksrg22ftss fridge wont make ice and
check your fill solenoid located at the bottom back of fride the valve may have a verry fine filter inside the valve ether clean it or replase the valve valve cost aprox 20,00 thanks from gilles
Mar 15, 2009 | Refrigerators
Algebra
59.88 MINUTES.
Example assume tub is 10 gallons.
10 minutes to fill is 1 gal/minute
10 gallons drain in 12 minutes =10/12=.833 Gal/Minute.
1 Gal/Min - .833 gal/min= .167 gal/min gain in water/min.
10 Gal/.167=59.88 minutes.
Apr 21, 2008 | SoftMath Algebrator - Algebra Homework...
Coral Sea Spas Ariel Platinum DA333F8 Steam Shower Unit Logo
97 people viewed this question
Top Coral Sea Spas Home Experts
Donni Steen
Tom Chichester
Are you a Coral Sea Spas Home Expert? Answer questions, earn points and help others
