Question about Acer Aspire 5500 5570-2609 Laptop
Unable to access my personnal settings using XP
I start up the laptop using XP, ,I then recieve a message "application has generated an exception that could not be handled" process 1d= 0x45c (1116), thread id=0x460 (1120).
It then offers me the choice of OK to terminate or cancel to debug.
Pressing either option I then see "loading your personnal settings" it then immediatlely goes into "closing your netwiork seetings" and goes back to the orignal password screen , I can't get past this loop of messages!
  • UR_FAV_GEEK May 11, 2010
    Try booting the computer to "Safe mode with networking " by pressing F8 after POST.
    Are you able to get into the selected user profile.
    If not, try selecting VGA Mode entry by pressing F8 after power ON
    Are you able to login ?
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    Hi, can you run your pc into a safe mode? you can try using system restore.
    Problem Solver:
  • 8 Answers
This sounds like a virus. Probably try running a virus scan with your virus removal software, if you dont have one download AVG - http://free.avg.com/ this is a free version of the software. Hope I helped.
iSpearz.
Posted on Jan 19, 2009
The application failed to initialize properly (0xc0000005). click on ok to terminate the application
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
You can read more about DEP at:
http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Mar 03, 2011 | Computers & Internet
Whenever i try to sign in, i get this "Yahoo! Messenger has stopped working" error message with the following problem details: Problem signature: Problem Event Name: APPCRASH Application...
Re: appcrash
Vista
Go to Start > Type in .....cmd........right-click on 'cmd' and select "Run as administrator".
After the cursor paste in : SFC /SCANNOW and press your 'Enter' key.
This procedure will scan Vista's protected system files
and attempt to repair or replace missing or corrupt files.
XP
Use the Administrator account
Go to Start > Run - Type in ....cmd.... > OK.
This procedure will scan XP's protected system files
If the result shows that the corrupt files are unable to be repaired, go for a 'banket' repair using Yahoo Messenger Help
http://help.yahoo.com/kb/index?page=content&id=SLN371&actp=search&viewlocale=en_US&searchid=1283483848357&y=PROD_MSNG_MSNG10
Aug 26, 2010 | Yahoo Messenger
Error running th game "Casino Inc." in Windows XP SP2
What Causes Windows Error 0xC0000005
A quick scan of the online technical forums and blogs reveal folks asking for help with this windows error. Your question may be the same as this typical request:
I'm running Windows XP and when I click to start one of my software programs I get this error:
The error 0xC0000005 is generated by an ******* "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
/NOEXECUTE
Oct 30, 2017 | Konami Casino Inc. for Windows
I have a dell latitude es400 and it keeps giving me a error messages like drwtsn32.exe-application error. The message in the box shows "the application failed to initialize properly (Oxc0000142). Click on...
You can reinstall the entire operative system with the CD that comes with your laptop, or with the restoration partition. See user's manual. This is the best way to fix error in a PC. Before restore the OS, backup your personal data.
May 14, 2009 | Computers & Internet
Lsass.exe-Unable to locae component
Boot from your WinXP CD and repair your existing installation. That is the component that controls security on your computer. When done with the repair and you can boot into your operating system again, you should do a full virus scan on the computer since there are several viruses that can cause this problem.
Apr 12, 2009 | HP Compaq Presario V2000 Notebook
Desktop doesn't appear on the computer.
hi there, The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
i would suggest that the ram in your computer has possibly broken down over a period, may i recommend obtaining some new ram, if you go to www.crucial.com they can provide you with information that tells you which ram you have in your PC.
Jan 25, 2009 | Acer Aspire 3680 Laptop
Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
/NOEXECUTE
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Oct 11, 2008 | Sony DCR-DVD608E DVD Camcorder
Intellinav.exe application error
/NOEXECUTE
CAUSE:
Aug 30, 2008 | Nextar Q3 GPS Receiver
Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Jul 21, 2008 | Motorola Mobility L6 Cellular Phone
Parallels Desktop
Hi toy4runner,
Did you check the permissions of the folders that need to be openend by parallels to get to the file? (just select the folders one by one and for ech of them press apple - I and check the permissions section of the information pane. Chnaces are Parallels is trying to access a folder but doesn't have the right permission.
If all seems okay, check this:
http://kb.parallels.com/en/4680
Hope it helps
Apr 27, 2008 | Apple MacBook Pro Laptop Computer with...
Acer Aspire 5500 5570-2609 Laptop Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
