Question about Radio Communications
Where can ipurchase original antenna for realistic pro 2021
  • 70 Answers
SOURCE: unable to operate no instructions
Try going to:www.who--da--man.com/.../PRO-2021%20Radio%20Scanner.pdf
Posted on Sep 23, 2009
  • 1274 Answers
SOURCE: Scanners Question: I Have Realistic Pro 2021
You can download it at www.who-da-man.com or www.scancat.com hope this was helpful......
Posted on Apr 17, 2010
  • 3 Answers
SOURCE: i have a realistic pro-2021 scanner and dont know
I have a pro 2021 scanner that runs through the channels but never picks up anything. I am thinking that there might be a bad crystal that needs replaced.
Posted on Sep 01, 2010
SOURCE: Realistic
Any radio shack should still sell the base antenna for this. It is cat. no. 20-176. You will need coaxial cable, antenna, (2) pl-259 connectors with UG176 adapter and a pl259 to RCA Motorola adapter.
Posted on Sep 23, 2010
  • 3 Answers
SOURCE: how do i program a radio shack realistic pro 2021
go to bettybearcat .com and you can get frequencys for your area
Posted on Jan 18, 2012
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Dec 21, 2017 | Radio Shack Radio Communications
Will Realistic Pro 2021 receive digital frequencies?
If it does not say digital on the scanner the answer is no. If it does, most likely it is a trunking system and will require programming using software and a computer.
Nov 07, 2014 | Radio Communications
Replacement Telescopic Antenna
See if this fits the bill. Otherwise stop in at a radio shack store. They sometimes have these n stock.
BuyTraxxas
Mar 01, 2014 | Radio Communications
Realistic pro 2021 is broken
Ummmm....the radio is at least 14 years old...ya think? They originally had a one-year warranty on them unless you purchased the 3 year warranty. In a word...no.
Feb 15, 2014 | Ritron /Jobcom Lapel /Jobcom JBS146D,...
Radio scanner no volume realistic pro- 2021 model #20-113 has loud squelch but voices only whisper what is the problem and how can i fix it. Thank You Lyman
frequency may not be accurate. get the correct frequency your tuning in to. could be off a few digits. then readjust your squelch.
Feb 16, 2010 | Radio Shack Radio Communications
I have a realistic pro-2021 scanner and dont know how to operate it other than turning it on or off can you help ??
Programming Frequencies
1. Select the desired channel.
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency.
4. Press [ENTER].
Selecting the Channel
Step 1:
1. Press [MANUAL]. Continue pressing until the display shows
Channel 20. Press [PROGRAM].
2. Press [2][0][MANUAL]. Press [PROGRAM]. (or press [PROGRAM],
press [2][0], press [PROGRAM]).
Step 2:
Press the keys (example 162.55)
Step 3:
Press [ENTER]. To program the next frequency, move to another channel in
this way. Press [PROGRAM] to advance to the next channel. Repeat the
same steps to add more frequencies.
SKIPPING BANKS
1. Turn the power on.
2. Press the number key that corresponds to the bank to be skipped.
3. The corresponding bank number indicator disappears from the display
and the entire bank is skipped.
NOTE: To restore the banks, press the number key again.
SEARCHING WITH YOUR PRO-2021
To search for transmission, press [PROGRAM], enter limits of frequency
range, and press [up arrow] or [down arrow] to activate "search."
1. Press [PROGRAM].
2. Press [LIMIT].
3. Enter the lower limit of frequency range to be searched.
4. Press [ENTER].
5. Press [LIMIT].
6. Enter the upper limit of frequency range to be searched.
7. Press [ENTER].
Activate "search" by pressing [up arrow] or [down arrow]. [Down arrow]
starts search from the highest frequency and goes down. [Up arrow] moves
in the opposite direction.
Press [SPEED] to accelerate or to slow down the search.
Jan 07, 2010 | Radio Shack Pro-2096 Base Scanner
Unable to operate no instructions
Sep 22, 2009 | Radio Communications
Realistic pro 2021 squelch problem
Just insert a sausage in there. A sausage is meat with skin around it.... a finger is the same thing.
Mar 20, 2008 | Ritron /Jobcom Lapel /Jobcom JBS146D,...
Radio Communications Logo
246 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
