Question about Kohler K-9511-BN MasterShower Shower Arm & Diverter - Brushed Nickel
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
I have a stall shower with a Kohler K-9511-BN MasterShower Shower Arm & Diverter. It is fairly new but has only worked intermittently. Now, when I turn on the water, it trickles out of the shower head. When I pull the diverter knob, the handheld shower works fine. What do I need to do to make the shower head work?
  • baggins96 Jan 17, 2009
    Thank you for your help. You were correct, the plumber's putty had clogged the shower head. I also removed the diverter housing and found the screw inside the housing had loosened, thereby causing issues with the diverter. The shower works better than ever now.
  • 73 Answers
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Posted on Jan 17, 2009
  • Jon B
    Jon B Jan 17, 2009
    awesome!!
How to replace soap dish on kohler mastershower slidebar. can't seem to take it apart.
Dear Sirs,
You have to deassamble the part then you can take of the shop dish
Oct 10, 2013 | KOHLER MasterShower Three-Way Brushed...
Water won't stay on
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 25, 2013 | Kohler K-14677-BN Loure bath- or...
Shower is dripping. how do you make sure you find the exact diverter replacement? Does it matter?
If you're talking about the diverter just like the one in that picture, then no. You do not need to get a Kohler diverter, as Kohler utilizes the 1/2 NPT(national pipe threading) threads that most showers are compatible to. You can pick one up from your local hardware stores. Make sure you teflon tape all the male threads before you install them.
Nov 25, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Can this diverter run both the shower head and a hand held shower.
This unit will allow the function of the shower head or the hand held shower individually. You can make both operate at the same time but the performance will be dismall at best.
Oct 23, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Leaking
Make sure you fitted the rubber O ring on the end of the shower flexible hose. That will seal the water pipe.
Mar 29, 2017 | Kohler K-9511-BN MasterShower Shower Arm &...
Replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Feb 28, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Mar 14, 2009 | Kohler Plumbing
Shower arm is loose
The best way is to cut a hole in the wall and fix it right. That will entail replacing the surface material, probably sheetrock. You could try some silicone sealant around the shower arm behind the eschusion. It will still move, but not much.
Mar 04, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Kohler K-9511
It sounds like there is dirt or other debris in the unit. Here is the installation guide. Take it apart and look for debris which would block the mechanism:
http://www.homedepot.com/catalog/pdfimages/5d/5d085947-93ec-433f-8f59-c8a23d2eb5ff.pdf
Feb 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Kohler K-9511-BN MasterShower Shower Arm & Diverter - Brushed Nickel Logo
521 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
