Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Paper jam I have brother 5 in 1 model MFC 240 and when I print I get a paper jam. I take the paper that is jamed out and when I clear the jam and reprint the problem of the paper jamed comes back again. Stating I have a paper jam over and over.
  • abbas_hussai Jan 25, 2009
    When i command to print the copy there was the message in display (Paper jam) i removed the paper and restart the printer and then try to reprint and the same message appears again and again what is th solution ?
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
  • Weldon Dube'
    Weldon Dube' Jan 22, 2009
    Normal
    0
    button
    over time
    Hope this helps.
    Bud
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Our brother MFC 7420 constant jaming of the paper when trying to print, what causes this?
clean the drive wheels that pull the paper in, they get shiny after a lot of use, use a alcahol pad to clean
Mar 08, 2011 | Brother MFC-7820N Laser Printer
My brother mfc 240 c is keep saying paper jam but we have move the cover and we do not see a paper jam how do we resolve this issue please help
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum. get more information to fix brother mfc printer paper jam problem .
Jan 24, 2011 | Brother Multi-Function Center MFC-240C...
Brother printer mfc 240 error 50?
this error is due to the machine does not work due to a paper jam.Clear the paper jam or may some mechanism not functioning properly check it ....
Dec 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
Print unable 36 error
The 36 error mean: The machine does not work due to a paper jam. Clear the paper jam, if doesn't work maybe a sensor is dirt or bad. To disassambly the printer you need the service manual and some know how ( electronics knowledge).
All the best !
Feb 21, 2018 | Brother Multi-Function Center MFC-240C...
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
how i can i plug mymulti-function center mfc model mfc240c to my pc
Dec 08, 2008 | Brother Multi-Function Center MFC-240C...
MFC 7300C
IT SOUNFDS LIKE THERE IS SOMETHING IN THE WAY OF THE PAPER PATH THAT IS CATCHINH THE CORNER OF THE PAPER, WHAT WE USUALLY DO IS TAKE A 8X10 FILE FOLDER AND MANUALY PUSH IT THRU THE PAPER PATHE TO SEE IF ANYTHING IS IN SIDE THEN REPLUG THE MACHINE AND SEE WHAT HAPPENS, GOOD LUCK BROTHER SR TECH
Nov 06, 2008 | Brother MFC 7300C InkJet Printer
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
BROTHER MFC 240 C
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Mar 31, 2008 | Brother MultiFunction Center MFC-440CN...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
129 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
