Question about Acer Aspire 5610-4648 Notebook
Key off computer keyboard
My cat jumped on topof my laptop and when I went to shoo him off one of his claws took off one of my keys....how do put it back on....do have all pieces......acer laptop Is there a web site you could direct me too that shows how to replace thi key? Appreciate much.....
  • 3 Answers
My 6 month old just pulled off two of the keys while "typing". I came here for the solution. After looking at the underside of the key for a moment, realized the bottom half slides into place. So I put my finger on the bottom half of the key first, slide up and down a couple times. The important part is to click the top part of the key in place last, by pushing down firmly. And vhah-la!
Posted on Jan 22, 2009
  • 51 Answers
Most of the time the keys are a pain to replace and if you do get it back on it is more prone to pop off again. If the computer is under warranty I would contact Acer and get the keyboard replaced. If not then search online especially Ebay for a replacement keyboard. Usually pretty cheap.
Posted on Jan 10, 2009
My cat stepped on the keyboard and the screen went black, I don ot know what keys she pressed
try rebooting the computer and as soon as it begins to start up (before the windows screen shows) tap repeatedly on the "F8" key on the top of your keyboard. when a boot menu appears choose "safe mode" when the computer loads you will have the window default settings and you should see your screen. If this works simply reboot the computer and it will load to normal mode. If this does not work let me know and I will attempt to help you further
Mar 22, 2013 | Acer Aspire 5515-5187 Laptop Screen
Screen went almost dark after cat walked across keyboard
Laptop keyboards have a function key that changes the brightness level. You access this by using the FN key on the bottom of the keyboard along with the brightness level, possibly the F8 key. There should be icons on the 'F' keys to show which key will increase the brightness on the display.
I hope you find this information helpful.
Brian
Jan 07, 2011 | Computers & Internet
Shift key doesn't work!
I think that you need a new keyboard a new computer will be two expensive for just one key on the keyboard
you can also try an external keyboard just one that you can plug into the USB port it will work out just fine
Jul 14, 2010 | Apple MacBook Pro Notebook
Laptop locked
puddy cat has stood on whats called a sticky key if you have a user book it will tell you how to release it.i cant quite remember the exact key to use but you have to press and hold down the fn key then hit one of the F keys.F2 for example, i just cannot remember which F key it is.
hope this helps
Jun 04, 2010 | Dell XPS M1530 Laptop
How to unlock a laptop keyboard
You can manually test which mode the keyboard is set to and change its configuration by following the steps below.
  1. Open a word processing program and type the word jump on the notebook's keyboard.
  2. If the word displays as jump , then the keyboard is set to its default mode. If the word displays as 140* , then the keyboard has been set to a number pad configuration.
  3. To switch modes, press Fn + Num Lock . (Fn key is next to Ctrl key on the left)
  4. Type jump again to confirm that the keyboard configuration has been reset.
The keyboard's configuration has been successfully reset.
May 27, 2010 | Computers & Internet
I have two keys that have come off. can anyone tell me how to put the back on
I've had the same thing happen when my cat clawed them off of my Dell. If you center the key above the spot and press until it clicks, that should do the trick.
I've noticed though, those keys are now prone to pop off again. So if that happens, use some super glue and just put a small dab in the very center and press back on.
Here's my video of my cat and the keyboard. He likes to sit on the keyboard and pry them off.
http://www.youtube.com/watch?v=Lsi1Yi03fNY
Jan 15, 2010 | Dell Inspiron B120 Notebook
2 keys have come off acer aspire 4520
If the plastic hinges and the tiny rubber press contact are still on the keyboard, you can align the key over the plastic hinge and press firmly down until you hear the key click back in place.
OR
You can purchase a replacement keyboard from several companies on the Internet. I purchased one from Yall Store - Use this link
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=i053roggch9fvk8hu1r9gph9l3&keyword=laptop+keyboards
OR
You can use a full size USB keyboard and plug it into the laptop's USB port.
May 07, 2009 | Acer Aspire 4520-5582 Notebook
In Zelda Twilight Princess I got the clawshot to early
there is 2 keys 1 is on the first floor 1is through a rooom on the second floor i know it works because i did the same thing
May 04, 2009 | Nintendo The Legend of Zelda: The Twilight...
Missing key
Hi Allie18,
If the cat has not eaten the small plastic clips that fixes the key to the keyboard, you are in luck.
Just place the key over the keyboard, align it so it is square with the other keys, push it down firmly until it clicks into place.
If this does not work then you have some missing parts or bent piece of plastic.
If you are game, you can remove an adjoining key by lifting it up, then you can check this key and see if it matches the other key for missing or bent parts.
Your Dell supplier may have replacement keys, if not you will need to replace the whole keyboard.
Nov 24, 2008 | Computers & Internet
Keyboard Fn appears to be stuck
check to see if the num lock key is on
Nov 22, 2008 | Dell Inspiron 1501 Notebook
Acer Aspire 5610-4648 Notebook Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
