Question about Canon imageCLASS D340 All-In-One Laser Printer
Clean fuser unit canon d340 copier
Multiple lines down page an about 1/8 inch intervals
  • 121 Answers
SOURCE: copier print quality
take a credit card and scrape the glass clean.  You only need to clean along the right side of the glass where the paper passes through.  Dirt that you can't even see will cause the lines.
Posted on Oct 27, 2007
headstrong
  • 233 Answers
SOURCE: imageclass d760 is making marks
it is either the image drum (on the cartridge) or the fuser.
if you have another cart. replace it and see if you get the same results.
Posted on Jan 04, 2008
SOURCE: Black line prints on back of paper
I have the same problem and I have not found any fix yet.
Posted on May 15, 2008
old marine
  • 1973 Answers
SOURCE: canon MF6530 copier
If your copies are clean when you scan them by opening the top and laying the original on the platen, you need to check the scanner for the ADF (automatic document feeder). It's a narrow strip of glass to the left of the scanning platen glass. Clean it with a soft cloth dampened with clear water. (Look for some type of deposit that aligns with where you see the line on the page.)
Posted on Jun 18, 2008
  • 3 Answers
SOURCE: canon imagerunner 3300 line on page
if you are using the feeder then there is something on the thin glass and it needs to be cleaned. if you are using the platen glass and the line is still there then you need a new drum.
Posted on Dec 29, 2008
E300 error message
Hi Good day!! It may be the fuser problem. u may need to replace the fuser or buy a new unit.
Nov 19, 2010 | Canon imageCLASS D340 All-In-One Laser...
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Hp 2420 vrtical line in page
This issue can be due to fuser. I am sure you have changed the toner cartridge.
To confirm its a fuser issue, please perform the following:
1. Try printing a configuration page from tray 1, pull the top cover, as soon as the media is 60-70% inside the printer.
This would stop the paper before reaching the fusing assy.
2. Remove the paper and check if the line exist.
If exists, fuser is not faulty.
If it does not, then transfer roller, laser/scanner assy is faulty
- If fuser is faulty, perform the cleaning page as following
1. go to configure device > print quality > create/process cleaning page
perform cleaning page 5-6 times, however, if the line is due to fuser, then fuser needs to be changed.
Let me know the next update.
- Nikhil
Nov 21, 2008 | HP LaserJet 2420 Printer
Horizontal black lines across page.
Horizontal lines usually indicate a toner cartridge that is not cleaning properly.
A. If the distance between defects is 38 mm (1.5 inches), 47 mm (1.85 inches), or 94 mm (3.7 inches), the print cartridge might need to be replaced.
B. Clean the printer.
1. Clean the inside of the printer and run a cleaning page to clean the fuser.
Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems.
To clean the inside of the printer
1. Turn the printer off and unplug the power cord.
2. Open the top cover.
3. Remove the print cartridge.
4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge
cavity.
5. Reinstall the print cartridge and close the top cover.
6. Plug in the power cable and turn the printer on.
Cleaning the fuser:
Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of your print jobs. To ensure optimum print quality, HP recommends that you use the cleaning page every time that you
replace the print cartridge or on an automatic interval that you can set up. The cleaning procedure takes about 2.5 minutes to complete. A CLEANING message appears on the printer control panel display while the cleaning is taking place.
To run the cleaning page:
In order for the cleaning page to work correctly, print the page on copier-grade paper (not bond, heavy, or rough paper).
1. If your printer model includes a duplexer, open the rear output bin.
2. Press Menu to open the menus.
3. Use (Up button) or (Down button) to scroll to CONFIGURE DEVICE, and then press (Select button).
4. Use (Up button) or (Down button) to scroll to PRINT QUALITY, and then press (Select button).
5. Use (Up button) or (Down button) to scroll to CREATE CLEANING PAGE, and then press (Select button).
6. Follow the instructions on the cleaning page to complete the cleaning process.
7. If your printer model includes a duplexer, close the rear output bin.
If this helps resolve the problem, please post a reply. Binary Bob
Sep 11, 2008 | HP LaserJet 2420 Printer
Brother HL2040 PRINTING DOTS
1- change the drum unit
2- check the fuser unit
Sep 06, 2008 | Brother HL-2040 Laser Printer
Canon d760
there are 2 possabilities for this
1 the drum unit is worn
2 the upper fuser roller/film has worn out
a visual check is needed to determine the cause
please get back to me if you require further assistance
Thank You
Jun 20, 2008 | Canon imageCLASS D761 Copier
Canon copier iR2016
My Canon copier IR2016 Problem code E007 Solve the problem pls
help me
Mar 02, 2008 | Office Equipment & Supplies
PC940 dark lines across the middle of the page
Either the Fuser/Heating unit is bad, or the optics are dirty.
What you can try to do to narrow it down, is to make a copy but.. STOP the machine in mid process by turning the power off. This will create a paper jam in the machine. If timed properly, your copy should be 1/2 way through the machine with some image on it. (Make sure that you are trying to copy something on the glass). The copy is not FUSED, so the toner will wipe off so be careful not to rub the page against your clothes/sleeve. IF the black line is on the page at this point, the problem is not in the fuser but probably in the fiber optics. If the problem is in the optics and will need to be cleaned. If the black line is NOT on the page at this point, then the fuser unit is bad and needs to be replaced.
Let me know how the copy comes out when you stop the machine in midway and I can see if i can give you any more suggestions.
Good luck.
Mac
Feb 12, 2008 | Canon PC-940 Black and White Copier
Canon imageCLASS D340 All-In-One Laser Printer Logo
69 people viewed this question
old marine
old marine
